twin turbo cam 218/220@50 lobe 115*
is this a good cam pick for twin on3 70/96 turbos
6.0 LQ4 317 heads stock w/T56 & 327 rear gear
68 camaro
fun street car with normal motor supporting items for cam and turbos
68 camaro
its "ok" if you don't want to go too far. Some of the hierarchy in the cam world will chime in im sure.
Id say Its a touch "small" for a cam in general especially for the 6.0. unless you have to deal with smog in certain areas id get a slightly larger cam. It would be a slight wakeup from stock, but I don't think all that work would be worth such a small cam. Id start at at least with 224ish cam.
For sure, get with Martin from Tick to get a recommendation on you setup and what you want out of it. he gave me a size I didn't even consider for my own rear mount turbo set of 226/235 114 cam with my car being a street driven car with a relitivly stock 5.7L.
Tick stage 1 or 2 turbo cams or customs...that cam will certainly fill better than stock and make more power but there's more power to be made with one of the cams I said
Ya go bigger, stock48's car is slow with it's little 218/218 cam. Fun street car?? What are you goals for the car? Is it ever going to see the track? How fast do you want to go? Are you concerned with fuel mileage, spool etc? Bigger isn't always better. I haven't been to the track in over a year. My truck caught fire and I replaced it with a Ford Escape so no more pulling a trailer. I went from a "custom" cam back to the stock L33 cam and I fell in love with the car again. It idles better, is quiter and makes way more low end torque. Yes I'm sure it's slower at the track but I don't really care at this point. I could just give it a pound or two of boost and be right back where I was before. Plus I'm getting close to 30mpg out of it on the highway at 65mph with a th400 and 3.08 gears.
Ive got a set of 410 gears, do you think that's to much gear.
If he makes any power at all...which he should, then 3.73 will go up in tyre smoke.
Mine's a YSI, and Ive tried 3.55 and 3.27
3.55 is slightly better on the street for normal driving, but overall the 3.27 is better..3.55 would be ok if your motor spins to over 7k with ease though.
The 3.27 definitely helps with traction.
I wouldnt even consider going shorter than 3.55 though.
I disagree. If the car is never going to the track , fine gear it tall, but even if you want to just take it to the 1/4 occasionally, you need to gear accordingly.
If tire size, shift rpm(and peak power rpm), and either hp, or trap speed are known, the best gearing can be figured out.
Slicks will solve tire spin at the track
Tall gearing in a stick shift just kills clutches, or slows the car down, from my experience - you can get away with it with an auto trans, but not a stick
With the 3.55 and 26" tyre, I was at 149mph at basically 7k in 4th gear
3.55 was too short for me.
But yes taller gearing will be harder on launch for clutch. I've swapped a couple of times between the 3.27 and 3.55. I'm on 3.27 now. And not a chance I'll be going back. The car is slower with the shorter gearing.
If I had 7500-8000rpm available, then I'd defo reconsider that though.
It does shift well at 7k, but it isn't ideal that high. Let's face it, not that many push beyond 7k.
But absolutely, more details are needed. Especially expected power and torque, and expected shift points.
IMO, the more power you have, rarely is taller gearing a bad thing. Especially on the street or any other severely traction limited scenarios.
