Intercooler swap gains 168rwhp
Old 09-05-2013, 06:53 AM
skinnies's Avatar
Originally Posted by THADD
That's why I don't understand all the people wasting their time with CX racing crap. You get what you pay for. I wouldn't even go as low of a level as Treadstone
Can you please post any REAL data to back up that comment about the treadstones?
How much pressure drop at say 30lbs and/or 1200rwhp setups? Bad IAT because of it?
I can tell you I DO have REAL data and they work.
Old 09-05-2013, 07:13 AM
SPRAYED 01's Avatar
Skinnies, I'm in the market for a new ic. Can you post which one you have and the data. I only want to do this one more time with the ic.
Old 09-05-2013, 07:45 AM
chuntington101's Avatar
INTMD8, what did Precision about the core? have they changed the design? Is it now design for higher pressure applications rather than high flow / low pressure ones?
Evidence yet again that when building / picking an intercooler you really need to spec it not just crab one off the shelf!
Chris.
Old 09-05-2013, 09:06 AM
THADD's Avatar
I don't have any data saved to support what I'm saying because my info came from reading, research, asking questions, and talking to the been there done that guys. I am also a real street class racer so I am only looking at it from that angle. This class is pinning the wastegate shut and running on full turbo. I can't afford to loose psi anywhere. Also one of the class front runners had a treadstone and swapped it out for a Bell and picked up over 100 hp. He has now been 5 teens in the 1/8. I find it hard to believe a CX racing or Treadstone intercooler will take a car close to my set up any where near the almost 4 second zone.
Old 09-05-2013, 09:21 AM
87silverbullet's Avatar
Originally Posted by AutomagicLS1
that's crazy. I'm finally ditching my cx racing cooler for a fancy shearer a/a this winter. Curious how much it'll pick up. I'll be on a much bigger air compressor though
Why don't you measure psi before and after the cxracing before dropping all that coin on the shearer unit?
If you're dropping 5-10 psi yeah I can see the benefit but if its 3 or 4 I would probably have to weigh my options. If I'm class racing, then yes, I'm looking for that 0.5 psi drop.
Old 09-05-2013, 09:49 AM
qqwqeqwrqwqtq's Avatar
Chris.
They said they changed suppliers for the core but it should still be fine. We sent the IC back to them and they saw no issue with it but sent us a new one to try (same results).
Fwiw they can build one with the 27x12.3x5 core that kicks ***, it's just the off the shelf "825hp" intercooler no longer flows as well as it used to.
Old 09-05-2013, 10:58 AM
venom ws7's Avatar
Makes me think before I order the intercooler for my new build..
Thanks for the comparison Jim...
Its been a long time since I've seen you post so I'll ask whats the new numbers on your old Badass TT ZO6??
Old 09-05-2013, 11:05 AM
THADD's Avatar
Skinnies what's you data? I'm curious to see what you have
Old 09-05-2013, 12:00 PM
I8UR4RD's Avatar
i read about this happening on an ATI intercooler once. its kinda the same story as some radiators that dont flow well and the car overheats blah blah blah. swap it out and its fine. they make these things by the 1000's and each one can vary slightly, and sometimes greatly apparently. i try to stress the importance of everyone doing the check pre and post IC but people seem to just assume its ok. glad you guys found some power!
Old 09-05-2013, 12:15 PM
skinnies's Avatar
Seeing less than 2 psi drop at upwards of 30lbs(controller spiked and made more than we wanted so I got that data) and seeing around 100 degree drop in intake temps. I have pressure sensor before/after and temp sensor before/after. I have the SMALL 6" tall twin intercooler from treadstone with not great airflow(in the nose of my mustang), rated way lower than I'm running the car at currently. It's been 132mph in the 8th on a slick track(so easy curve with some pedaling) at 3400lbs in a car not setup for the 8th.
The treadstone is fine for 99% of a2a street cars not looking for every last hp out of their setups. I just threw in the 6" one as I got it for a good deal used and planned on a2w later so didn't buy a new one.
Old 09-05-2013, 01:31 PM
Intresting results skinnies! Nice temp drop over the core to, ESP as its only a short one! Be intresting to see what a 9 or even 12 inch high core could do. Might see a little more presure drop but should cool even better. What's the thickness of the core??
Chris.
Old 09-05-2013, 02:34 PM
  #32
THADD's Avatar
Verticle style intercooler?
Old 09-05-2013, 03:09 PM
  #33
9 Second Truck Club
stock48's Avatar
Treadstone vertical here. I have never tested drop tho lol
Old 09-05-2013, 03:48 PM
  #34
THADD's Avatar
I just ordered a verticle straight from Bell. I will test it and post up info once I'm back from LS Fest. Lots of good info here .......
http://www.bellintercoolers.com/page...AQ.html#FAQ_17
Old 09-05-2013, 07:42 PM
  #35
turbocuda's Avatar
Come on now.....we now you ordered it just because you are **** like that!......has it come in yet......where is the car now...wouldn't mind coming over and seeing what's going on.
Old 09-05-2013, 08:49 PM
  #36
LS1Tech Sponsor
Slowhawk's Avatar
Nice post to show you can get bad intercoolers even from a good name place.
I run a cx intercooler on my personal car. 5.2's in the 1/8 at 18 lbs boost. Converter limited.
Old 09-05-2013, 09:19 PM
  #37
SPRAYED 01's Avatar
Have you measured pressure pre and post, slowhawk?
Old 09-05-2013, 10:03 PM
  #38
Fathouse's Avatar
Skinnys, what do you mean 100 degree drops in temps?
Do you log ait going down the track?
Old 09-05-2013, 11:32 PM
  #39
THADD's Avatar
Well yeah kinda plus you pushed for me to as well, lol. It's at my shop. I will hit you up on Tuesday and you can swing by after work
Old 09-06-2013, 06:08 AM
  #40
skinnies's Avatar
Yes I log iats, I have a temp sensor before and after the intercooler so I can see exactly how much temp it is dropping through the intercooler. I have this intercooler....
http://www.treadstoneperformance.com...cooler++1000HP
I would like to step up to the 9" tall core one to see how much of a difference it makes and/or a bell core. For what I am doing for now, the 6" tall one works fine though.
Quick Reply: Intercooler swap gains 168rwhp
