dual springs needed?
Old 09-05-2013, 05:54 PM
BOTTLE ROCKET's Avatar
Default dual springs needed?
IS it necessary (or highly recommended) to run dual springs on a supercharged engine
I have a smaller cam (571 lift) with the PSI Beehive springs now, and with a new bottom end, will try to push boost into the 15 psi range.
What do you think?
Old 09-05-2013, 05:55 PM
allout06's Avatar
Yes. Wouldnt think twice about it.
Old 09-05-2013, 06:04 PM
coolmanvette75's Avatar
Ohhh yes. Your pistons will thank you later should said spring break...
Old 09-05-2013, 07:33 PM
OK, thanks guys; I guess I might as well go ahead with a bigger cam since I will have the supporting valve train.
Old 09-06-2013, 01:04 AM
Customizing Director
MadIceV8's Avatar
Just for the safety aspect alone. Yes.
Old 09-06-2013, 03:22 AM
9 Second Truck Club
stock48's Avatar
I'm running Isky singles @.570' and 23 psi.
Old 09-07-2013, 06:07 PM
Secs-10's Avatar
I was running isky singles I ordered from stock48 on my last setup with a sbe 5.3 and 20+ psi. No problems.
Give stock48 a shout he'll hook ya up on an isky cam and spring combo that'll scream.
Old 09-07-2013, 07:32 PM
GMCtrk's Avatar
For the price, I went with Tooley duals. I had a PAC 1218 snap and valve only mildly kiss the piston without dropping. But the single spring also had 3 years of duty on a .598" lift cam which was probably the most influential factor. Added boost and it broke.
Old 09-07-2013, 07:39 PM
Blackpanther99's Avatar
Yes I would recommend dual springs. You can get a good set of springs from Brian Tooley for a badass price and good quality.
Old 09-08-2013, 12:37 AM
Forcefed86's Avatar
How many miles you planning on putting on this thing? How high do you rev the motor?
I run with roughly the same lift and 21lbs On pac 1218's. Don't rev the motor much over 6k though.
Old 09-08-2013, 03:17 PM
allout06's Avatar
I dont see why you would wanna cheap out something as affordable as a set of valve springs.
Old 09-09-2013, 09:33 AM
Forcefed86's Avatar
Not a matter of cheaping out. It's a matter of choosing the correct spring for your application. If a dual spring isn't needed there is not reason to run one. Running excessive spring pressure is just a bad as to little pressure. I think it falls along the lines of "bigger isn't always better".
Old 09-09-2013, 01:06 PM
I checked with him and got a recommendation on a set. I am trying to keep the cost down, but not worth losing a motor for $300. The only issue now, is that if I am going to invest in springs and the install, I might as well spend a little more and get a blower cam
Never ends....
Quick Reply: dual springs needed?
