What all do I need to replace an LQ4 cam with a stock cam from an LS9?
Old 09-05-2013, 10:37 PM
rp0029's Avatar
Default What all do I need to replace an LQ4 cam with a stock cam from an LS9?
From what I understand, I need a 2005 LS2 front cover.
I also need a 2005 1x cam sprocket?
Will this work?
I also need a 2005 LS2 chain damper, anyone have a part number?
As well as an extension harness, which I can make.
I am putting a zl1 supercharger on my car and I want to use all GM parts.
Is there anything else I need, and will this work?
Old 09-05-2013, 11:55 PM
}BlueFire{'s Avatar
Sounds about right excluding sensor and can. the timing chain dampener numbers are 12588670 Timing Chain Damper, Black, LS2, 1.762 Bolt Center
88958607 Timing Chain Damper, Tan, LS1/6, 2.187 Bolt Center
Depending on the year of your block will determine which dampener. I believe 05+ take the black one.
Quick Reply: What all do I need to replace an LQ4 cam with a stock cam from an LS9?
