Twin turbo car ran a little hot saturday. Water pump maybe?
I drove the car to my friends house which is about 30 miles away, all interstate, and the needle crept up to about 220-225 which started worrying me. I know my fans need to be replaced with some better ones but rolling down the highway they aren't a factor. It still has the stock LS1 water pump on it and I was thinking maybe it is not performing up to par. It was damn hot that day though, 95+ and heat index over 100 so maybe it is normal on that hot of day? The car does not have A/C.
Should I look into replacing the water pump you think? Or is it normal for on that hot of a day and that long of a trip, 30 miles one way, for it to run a little warm?
That kind of temperature creep is usually a sign of not enough radiator. Like you mentioned interstate driving if the air dam is in place should have little need of the fans.
Here "Mishimoto fans" is most likely the problem, there was a thread not long ago where someone else was having issues with the cheap fans. Also in that thread I seem to remember the guy sayin they told him they had cahnged suppliers as the old style was not cutting it. Get yourself a couple of SPAL fans and good high current realys powered off the battery and I bet you will solve your issues.
Lol im throwing radiator in the rear because of this. Even though I was using stock fans as pushers and stock radiator when I was experiencing this. Done started the relocating so no turning back lol. Hopefully I can hold below 180s with it in the rear as my goal with a cheap aluminum aftermarket radiator and stock fans as pullers again.
OP my temps were 217-226 on a 120 mile cruise labor day.
I also forgot to mention it has developed a pretty loud annoying squeak/squeal, more squeak really but was thinking it might all be the water pump?
