Help picking new turbo going from 960-1200rwhp
Old 09-11-2013, 09:48 AM
mike13's Avatar
Default Help picking new turbo going from 960-1200rwhp
I presently have what I think is called a S483 (83 billet comp/ 92mm comp) T4 housing. Here's my problem this turbo is as physically large as I can fit. Also needs to stay a T4. Any suggestions?[IMG][/IMG]
6.0L
390CI
ETP 245 heads
4L80#
Old 09-11-2013, 09:49 AM
mike13's Avatar
As you can see it's a tight fit.
Old 09-11-2013, 09:55 AM
mike13's Avatar
Old 09-11-2013, 12:27 PM
9 Second Truck Club
stock48's Avatar
Billet S476/06/1.25 T4 and port the T4 turbine housing. Im currently running the S476/92 but will be testing a S476/96 here before long. Might get 1050-1100 HP with the billet 76 but thats a lot of power. You're going to need a GT5088 to go 1200 +in a T4.
Old 09-11-2013, 01:01 PM
LS1Tech Sponsor
hellbents10's Avatar
I think Jose is working on putting in a 96mm turbine in the t4 housings now. With his new compressor wheel I think 1200rwhp is attainable.
Old 09-11-2013, 01:58 PM
9 Second Truck Club
stock48's Avatar
It might be but housing will need a lot of work. I believe he is working on an aftermarket housing that should solve that issue.
Old 09-11-2013, 02:04 PM
WheelsUp84z's Avatar
Also look into a race cover if you can.
Old 09-11-2013, 02:36 PM
mike13's Avatar
I'm thinking the new billet 84etr and 96mm turbine would might be the ticket. I need to see if Jose can fit bigger wheels on my present turbo.
Old 09-11-2013, 03:15 PM
slowlsx's Avatar
I dont think you will see that much of a gain going to the 84m... they were already having BP issues wuth the billet 80 and 96mm turbine. My oower goals are the same as yours and I am looking at the GT5088
Old 09-11-2013, 03:58 PM
mike13's Avatar
Already have the race cover.
Old 09-11-2013, 03:59 PM
mike13's Avatar
Didn't know that, thought the 96mm turbine might have been the answer.
Old 09-11-2013, 04:28 PM
LS1TECH Sponsor
DrTurbo's Avatar
96 is the largest on a T4. We are working on a 100mm turbine, but only available for the T6 models.
Old 09-11-2013, 04:30 PM
smokeshow's Avatar
How much boost did it take to make 960?
Old 09-11-2013, 04:31 PM
mike13's Avatar
Can I get 1200rwhp out of the 84etr with 96mm turbine on a 390 engine?
Old 09-11-2013, 04:35 PM
mike13's Avatar
It has a set of ETP 245 heads and only needed 14-15lbs. My concern is if I try and push it that the back pressure could hurt the motor. 92mm turbine isn't a very big wheel for the size motor and flow of the heads.
Old 09-11-2013, 04:39 PM
smokeshow's Avatar
Have you measured back pressure? I've never seen a gas engine damaged from excess back pressure. They just stop making power. If you're really concerned you could use a larger diameter downpipe if you can fit it...that would reduce back pressure.
Old 09-11-2013, 04:47 PM
mike13's Avatar
No haven't measured and absolutely no room for anything larger than the 4" I'm already running.
I have no proof of the back pressure hurting motors but I've seen 2 motors lift and torch the heads when the small turbines where pushed hard. Not saying that was the cause but it looked possible.
Old 09-11-2013, 05:03 PM
smokeshow's Avatar
Hmm, interesting... Actual cylinder pressure is far higher than back pressure, so I wouldn't expect back pressure to have anything to do with lifting a head. However small turbines tend to spool faster so its possible that boost coming in too soon in a spot where the tune hasn't been dialed in well can detonate and push the heads up.
Old 09-11-2013, 06:50 PM
LS1TECH Sponsor
DrTurbo's Avatar
I think we can get you DANG close. We are building a max effort T4 76mm now for a certain customer on this board now. Should see what it does very soon. I'm thinking 7's will be possible with our T4....if not RIGHT at it.
Old 09-11-2013, 07:07 PM
Blackpanther99's Avatar
Thats impressive Jose. How many cubes does the block of the customer have?
Quick Reply: Help picking new turbo going from 960-1200rwhp
