what is this thing on my ZL1 supercharger?
No, you don't have to. Its really only for torque management and boost limiting functions. The ECM will send signal to that solenoid to put boost to the bottom port on the actuator to open the bypass and bring boost down. Otherwise, vacuum on the top port just works to open the bypass once the throttle is closed.
No, you don't hook it up to the throttle body, just somewhere behind it but above the rotors. You want it to see vacuum as soon as you close the throttle. The line is already referenced correctly in stock form; you just have to hook it directly to the actuator instead of the solenoid.
