6.0 shorty headers instead of manifolds.
Old 09-20-2013, 05:13 PM
Preston99WS6's Avatar
Default 6.0 shorty headers instead of manifolds.
Just curious if these would be a better alternative to truck manifolds as I am getting ready to build a new hot side, These are much cheaper under 200 dollars for chrome moly and made in America by Gibson and can be had in ceramic, stainless or chrome moly, compared to custom turbo headers, they would also be direct fit and feature tuned ports, In other words if you built a kit that utilized manifolds without the v banded flanges. Gaskets are obviously junk and I wouldn't run them. That being said what are your Thoughts pro-cons?
Old 09-20-2013, 05:51 PM
1969x11's Avatar
Wouldn't hold in as much heat as the manifolds and would be more prone to cracks, but they would look a lot cleaner. Would you wrap them?
Old 09-20-2013, 08:23 PM
I would get the ceramacoated version and probably wrap to retain heat, My car will be 95% drag car 5% street car once it does its next transformation. I will also build a turbo brace if I go this route. Looking to get everything I can get out of a forged 6.0, LS6 intake, ported 317 heads, S480 turbo, and the custom for my setup Martin Cam I just bought, TH-400. Still got to order the new converter, Not sure who to go with my current converter is from Cameron but its left over from the nitrous setup and too loose up top, was only a 200 RPM drop from 2nd to 3rd on 15 psi before the motor hurt itself last year. Its was perfect with the spray and N/A just not up to the task with the turbo, so i might give him another go. Waiting my the short block get back from the machine shop to get started at the moment.
Plan is 3200 race weight, and go as deep into the 5's as possible on kill for some grudge and run some local 6.0 index's and 275/ 10.5 28" tire shoot outs, for this coming year then maybe pick up a billet S476 for some RS 275 for the next. Got to add more cage for 8.50 cert to do the RS 275 thing though.
Old 09-21-2013, 09:25 AM
mrstepheneades's Avatar
Man I just realized you were in Rockingham. Must be nice have a quarter mile track in your back yard. I run there one time in my old slow car lol. Like a 2hr drive for me though if I remember.
But on the headers, if you have a good turbo brace I think they would look really clean and do fine. Manifolds obviously stronger and hold heat in more because of the thick cast but shorts would flow better. Pros and cons with everything I guess.
Old 09-22-2013, 08:47 AM
I new about the heat issue, My question really was is the potential power gain really worth the extra 100 dollars? I also like the potential for the cleaner look. By the time they are coated and wrapped heat retention should be close to that of the exhuast manifolds.
As far as Rockingham goes I am 9 miles away from that track, a hour away from darlington or Fayetteville, 1.5 hours to Z max, and Orangeburg, SC so plenty of local spots to jump in, Several tracks in SC constantly hosting (like every 2 weeks) shoot outs like this one.
http://www.carolinahorsepower.com/fo...ad.php?t=15898
This ones has a little cheaper payout usually its 5K or (10K on holiday weekends) and good for the grass roots racers in the area.
Old 09-22-2013, 08:49 AM
gnx7's Avatar
truck manifolds have made 2000hp and gone nearly 200mph in the 1/4 by the Ohio Boys.
Spend the money on a better turbo.
Old 09-22-2013, 09:27 AM
DEFYANT's Avatar
Huron Speed just released a set of V-Band style "truck" manifolds. I would check them out, but yes, the Ohio Boys have been 200MPH... Can't want much more than that.
Old 09-22-2013, 09:55 AM
knuts82's Avatar
I started with JBA shorty truck headers.. Seems to work pretty good.
Old 09-22-2013, 01:40 PM
I already have a S480 with race cover, not going to change that until I decide to go to the billet 76mm, granted there is always more on the table there. Probably a wasted 100 dollar bill performance wise, nice visual up grade though IMO.
Old 09-22-2013, 01:44 PM
That looks pretty good man.
I like the look of headers much more than the manifolds, I know manifolds work very well, seen several cars with them doing work.
Old 09-22-2013, 02:05 PM
TT427's Avatar
Did you see the headers by Huron? They duplicate the truck mani. 395 till the end of the month.
Old 09-22-2013, 02:08 PM
TT427's Avatar
https://ls1tech.com/forums/forced-in...manifolds.html
Old 09-22-2013, 02:36 PM
Tiago's Avatar
I used the JBA's in my setup as well. Never cracked so far in 7 years.
Quick Reply: 6.0 shorty headers instead of manifolds.
