What Makes A SBE 5.3 or SBE 6.0 A Better Option Than A SBE 5.7?
I see all these turbo builds with stock bottom end 5.3's and 6.0's, but rarely see any with the 5.7. Is there a reason for this? If I were to do a turbo build, would it better to get a 5.3 or 6.0 rather than use my existing 5.7? Will a stock bottom end 5.7 hold as much power as I see these 5.3's and 6.0's putting down? Sorry if these are dumb questions, it's just somethign that I've always wanted to know the answer to.
I think the main reason why people go with 4.8/5.3/6.0s, is their quanitity and how cheap they are. An LS1 should be fine to 700ish, but when it lets go its expensive to replace.
The newer gen4 5.3's/6.0's also have better rod/piston design with the floating pins so they hold up to boost a little better then the 5.7's. Since the last year of the 5.7 was 2002 in the F-bodys they don't have as much technology as 2005+ LS based engines. That along with having the iron block make these engines more desireable for boost as well as being cheap and plentifiul. Now if you were to stick a set of pistons and rods into your 5.7 then you would have a good foundation for 900-1000HP. I have a really nice LS1 block and crank that Im looking to sell for a good deal that would make a nice shortblock with aftermarket rods/pistons. I came across a good deal on 05 LQ9 6.0 complete so I went that route.
The following users liked this post:
Jwooky (02-28-2024)
If I go the turbo route, I'll either use my 45k LS1 that's already in my WS6, or pull it and buy a junk yard 5.3 or 6.0. In all honesty, I would like to make around 800rwhp, with room to grow by upping boost. I've been seeing great things out of the S480 turbo and I think that turbo would get me to my goals and leave some room to grow.
rpturbo (02-28-2024)
I think it would be best to pull mine and find a cheap 6.0. Any idea on what a good turbo would be for a 6.0 with LS6 intake, will get a custom turbo cam from Martin, 6 speed with Monster stage 3 clutch with Tick Master, 317 heads, .660 BTR valve springs, etc. like I said, I would love to make 800rwhp and be able to run high 9's at the track. This is a 90% street car, so the turbo needs to spool pretty quick on the street. Any ideas? What's my best wallet friendly option?
Captain Double Post
i just think its because for 1. there cheap,ive seen some people pay 200 for a 5.3,2. its a cheap option when you spin a bearing or your ls1 fails,plus with the other pros truck motors are most of the time in good shape,i mean really who outside of us beats the hell outta there trucks lol most of the time they have hsd a very easy life
Yeah, Martin helped spec my current setup. He's a great guy who'll I will consult with in regards to the cam for the setup. I will also pick his brain about what turbo to run too. The reason for this thread was more out of curiosity, but I do know a turbo build is in my future and could happen as early as this winter.
Something in the 76 compressor/75 turbine range for a 5.3 is perfect. Either Precision or Turbonetics make good units. I will be going with a Comp unit if I don't sell my GTO.
Btw parting out your current build will probably fund your entire turbo build for sure and then some.
