Looking to buy a wide band for my turbo 6.0 build, AEM?
Old 09-28-2013, 02:10 PM
T/ALT1's Avatar
Default Looking to buy a wide band for my turbo 6.0 build, AEM?
Looking at the AEM 30-4900 setup that has a fail safe for AFR, data logging for boost pressure? Mostly needing the setup for my EFI source Gold box can monitor AFR and adjust.
Old 09-28-2013, 09:09 PM
Black Reign's Avatar
What is your question? AEM is a fine product for WBo2's, there are better one's and there are worse one's. But I have never used a fail safe, would rather buy a eBoost2.
Old 09-28-2013, 09:33 PM
Blackpanther99's Avatar
AEM TruBoost works more than good.
Old 09-28-2013, 10:21 PM
conan's Avatar
My AEM wideband was right on with the dyno jet reading last time getting tuned. No problems here.
Old 09-29-2013, 10:34 AM
allout06's Avatar
I use the Innovate LC-1
Old 09-29-2013, 10:59 AM
Precision1231's Avatar
I use Daytona Sensors WEGO IV. It logs single or dual Widebands, map/TPS, and RPM. It also has a 5v output to you PCM for your o2 sensor.
http://www.daytona-sensors.com/WEGO4.html
Old 09-29-2013, 11:05 AM
wild1100's Avatar
I have no problems with my AEM wideband. I just don't like that it cant be recalibrated. But it hasn't ever let me down. I also have a LM2 on my other car it hasn't let me down either hell I have swapped both around before because I thought the AEM was reading wrong lol. It wasn't.
Quick Reply: Looking to buy a wide band for my turbo 6.0 build, AEM?
