manual rack and relocated alternator
For those of you that have a manual rack and relocated the alternator to the passenger head, what did you do to route the belt back around?
I'm thinking getting a 6 ribbed idler and put it on the stock idler bracket, but I don't know if that will be enough angle for the water pump.
I'm open to ideas
I'm open to ideas
No, it's the CBR alternator relocation which eliminates the tensioner all together. The alternator becomes your tensioner with the setup. I added another pulley to put some more tension on the belt.
It's a Comp cams tensioner that looks similar to the Katech. You will probably need an assortment of washers to space it correctly but it works great. That was the only way I could see getting enough belt wrap. I wouldn't trust having the water pump run like the ones above.
