pics of lq4 in the car and hot side.
thought id post a few pics of the 6.0 in my nova the hot side I built on the stand worked very nice . didn't have to change it at all just had to finish the last bend to lower the turbo and fit it under the hood. I also turned the turbo to get a better shot for an air filter and it also aims the downpipe flange to eliminate a bend. it all need to come off to paint it and finish welding a couple spots but it looks better than I had hoped.
lq4 stock rebuilt shortblock, with ring opened up, 317 heads just a fresh valve job,ls9 gaskets and gmpp bolts, comp cams 206/212 528/540 lift 114 , comp 7.4 pushrods 1.75 comp rollers, pac 8017 double springs. stock truck intake , it will get 80#injectors , tc-78 turbo. 350 th and 3.23 gears. car should be about 3400 lbs. looking for 10.0s when tuned in .
Nice and you should have no problem exceeding your goals. The only place you could do better is the tranny but you could always do that later. Good luck and keep us updated.
yes it will be pumpgas to start I might go e85 later it is about 20 miles from me. and I don't want to start off with anything else that I haven't messed with before. trans might get replaced by spring if the money don't run low with the engine build. lol.thanks
it has the f1-68 turbine with a .96 housing but I want to get it running then look for a bigger housing I think they make several up to a 1.52 ar. this is my first turbo ls build so im starting out mild and working up . the car is only getting a 6 pt bar so 10 flat or 135 mph is all im looking for .
not really I did spend some time cleaning it up with the biscuit and a hand grinder but it was just warm. then when I welded it I didn't just weld it in one pass I kind of spot welded it and moved around and didn't let the heat get to hot in one spot. welded up very nice better than I though it whould. much better castings than the old stuff.
