71 Nova single turbo, am I on the right track?
Hey guys, I need some reassurance on my selection of parts. I'm using a stock 5.3 with a Turbonetics 76mm turbo with .96 A/R ratio thinking of running 7-10 pounds of boost. From my research I'm going to use a 50mm wastegate and bov, 60 lb/hr DeatschWerks Fuel Injectors.
Anything wrong with my selection of parts? Do I need a boost reference fuel Regulator? Should I replace the valve spring with the ls6 springs?
I think you should change the valve springs and push rods regardless just to be ready for boost .
I have seen guys run without a boost reference fpr but they needed bigger injectors . the fuel pressure stays set so the injectors have to ad the extra fuel so 80# might be a better match. im sure someone with first hand experience will chime in. good luck on the build. im turboing a nova /lq4 myself.
60 lb injectors can do like 700whp i think so as long as that is in your goal you are ok.
valveprings i would say are good to do, as i have blown open stock springs around 8-10psi
if they are higher mileage they are weaker also.
Pac1218 springs are only 140 dollars and procomp are only 50 dollars
stock pushrods, rockers, keepers etc are fine
Something like this will work?
http://www.summitracing.com/parts/na...9224/overview/
As a point of reference I am running SD 60lb injectors with the pressure pulled back to 43psi on a boost referenced regulator. 6.0L LS2 at 7psi of boost my injector duty cycle is under 60%. I did hit 10psi of boostthe car stayed well in the 10's AFR but I wasn't logging duty cycle when my wastegate fitting came loose. I'm sure it was fine. Also only running a 44mm wastegate that held boost all the way down to 3psi.
