88mm,High ram, all black turbo build.
It's a 47-88 all work done by Fast Track Performance I'm sure most of you have herd of it awesome work and a great guy. Looking for 600 RWHP keeping it mild for now building a 370 looking for around 1200 on it.
There was a lot of time put in this build to make it as clean as possible and look great I'm glad Anthony took the time he did and put up with all the changes I came up with and also ading his advice (much needed). There is only one rubber line on the car and it is on the bottom of the wast gate. All the rest of the lines on the car are braded stainless with black fittings even the -20 radiator hoses . The car is on E85 with one in tank pump that feeds three thirsty pumps in the surge tank going to 127lb injectors. It will be on low bost for now but built to take what I can throw at it.
. That is the same thing I'm wondering lol. It should have no problem making 900whp on this size motor (stock LS1) but could prolly support almost 1200 on a 5.3 the exhaust housing has a lot to do with making power on a V8 if I do got with a 370ci motor in the end I will upgrade to a 100+mm turbo to support my goal of 1200whp.
I know block/internals/heads are stock but what oil pump, timing chain, valvesprings, etc did you go with. Your car is almost an exact visual clone of mine and I am about to put on my turbo kit.
