Procharged F1a Camaro
Procharged F1a Camaro Now F1C 10.5
Made a new pass with my
Stock bottom end lq4
afr205 heads
brute speed blower cam
victor jr intake
procharger f1a 10psi
th400
9inch rear 3.50 gears
pump gas no meth
3740 race weight
on goodyear drag radials
afr205 heads
victor jr intake
th400
pump gas no meth
3740 race weight
LS1Tech Sponsor
That is awesome for only 10 psi of boost, congratulations! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
http://thumbs3.ebaystatic.com/d/l225...LM-sgS44Ew.jpg
I have the Aster bracket and bought this.. It does'nt hit anymore. The factory pulley has a dome shape to it. The ebay pulley (wazee pulley) has a slighter dome but gives you about .081 from tensioner aster pulley to power steering pulley. I'll send some pictures in a few days to show you.
glad i got the wazee now. solved a problem before i knew i had it.
stmz28.....that car is flat out freakin moving man. id love to see a vid of that pass if you got it. you thinking of turning it up any more or you wanting to keep it where it is for now. i dont see many other people running sub 9.50's at that boost level/weight.
LOL, I'm getting sh$t everywhere for going with the BFG dragradial (old tread not the fire looking one). Honestly that is a great tire I did have great traction the first 40 feet which is where they prepped the track really well. My issues came right after the 40 feet, half way down 1/4 and 3/4 of the track. It was funny I let off the gas a few times with my first run but it felt really strong. That was running somewhat rich 10.5-11.0. My issue now is trying to find out if I have air leaking out of my hoses or my intercooler is restricting my air flow. I'm only getting 13 lbs @ 6900 rpm. My car feels strong as hell though. I'll be taking my tranny off the car soon and checking my level 5 Monster clutch that only has about 800 miles on it and gave out. They should warranty it with those miles on it. I'll keep everyone in the loop.
FYI, I was seeing around 11 -12 lbs of boost when I had the factory power steering pulley. You could see how my bracket tensioner pulley dug into the poweer steering pulley. After the switch I gained 1 lb of boost towards the end of my rpm, 6900 rpm. This is with the 3.90 pulley which should max out my f1a. I recently upped my rev limiter to 7300 but since my clutch went out the very first time at the track I would not be able to tell you how much more boost I gained if any with raising my rev limiter.
One other thing when my tuner had my car and was tuning it, it had the truck hat on the F1A. He sent me a picture showing my car at 15 lbs of boost. When I got the car back I switched it back to the orginal hat beecause the truck hat kept falling off so when I made some logs with the old hat on the f1a it only showed I was making 13 lbs of boost. So that may be why I'm seeing less boost.. I'll switch that back when I fix everything and advise on the restrictions between hats. Sh$t I think I solved my problem. Damn hahaha
