S475(or recommend me something) on 5.7 vs 6.0 and truck/c6 mani questions
Starting to do some research for winter build with the new car. Plans are build the turbo kit this winter on my stock fbody then swap in my lq4 next year. I really only want to build the kit once and buy one turbo lol.
I was looking at an s475 seems like it would be a good size for the 6.0 but maybe a little laggy on the stock 5.7, which I'm ok with as long as you guys think it will still light about 4k???? Car will get the 6.0 with a tick custom cam next year.
Is there a better turbo that could work for both the 5.7 or 6.0? I'm open to options would like to keep the price around $900 for the turbo itself.
Next question on the c6/truck manifold. Looking to keep my ac. I'll be standing up my radiator using the same griffin everyone uses. Probably have to modify the ac lines if need be. I won't know till I get into it I guess. If I'm using the c6 manifold do I have to use a turbo k member if I'm going run front bumper down pipe? Car isn't a daily so I was thinking I could just dump the down pipe out the bumper instead of going back through the k member but I'm not sure if it's required using the c6 mani around the compressor.
Are all c6 ls2 and ls3 manifolds the same?
Thanks!
Thanks!
I have a 6.0, c6/truck mani, griffin rad stood up. The tc78 will fit with out standing it up, iv did that first when it was still a 5.7. Now with the tc you can get a 75mm turbine.
The bw unit is going to make a bunch more power over the tc but is physically huge.
What are your power goals?
If you are dumping out the bumper i don't think there is any need for an after market kmember.
There's about a 6% difference in displacement between a 5.7 and a 6.0, so don't expect a great deal more power or spool between the 2. Turbos themselves often dictate the power output, not the displacement. For example, there are 4 cylinders making 700+ hp on that same turbo.
Go with what is available and within your budget. Don't over think it too much. There are tons of guys in street driven 5.3s that are making your power goal and picked up their engine at the local yard for 300 bucks.
What's the gate spring going to be? Basically its going to be difficult to fit the bw turbo even with the radiator moved up, but possible. The bw will make more power and have less bp. If go with that.
It depends a lot on backpressure. If you get a smaller turbine, you will have more backpressure and it will blow the spring open before the advertised spring rate. An example might be a ten lb spring only netting you 7 psi if there is a lot of backpressure. What fuel will you be using? I would match the spring to your eventual goal if you are going to be running good fuel. If not size it small and you can usually add a different spring later.
I'm partial to the S475 as I have one myself but they are physically large. I'm not sure how easy its going to be to plumb a T6 kit with a 4"+ DP and keep the AC. I'm sure its been done before tho.
Here is a picture of my old On3 76mm and the S475 to show you the side by side difference.
Thanks for the info! I like the price of BW also but open to suggestions of other turbos as well.
It looks huge in that pic lol.
I figured the bw would fit by standing up the rad and moving the battery to the back and front bumper exit down pipe. I was thinking mount it so the air filter would be right where the battery is located now and the down pipe across the front of the engine out the drives side front bumper.
https://ls1tech.com/forums/staff-vehicles-showcase/617938-na-ty-turbo-ta.html
Check out his turbo location. Kinda like what your saying. You have to scroll down the page a little bit because he was super charged at first then he went turbo.
bump for more opinions because ive searched till blue in the face and with so much info out there im no closer to picking a turbo lol
Now I was reading that a pt7675 could be a good fit, but then the same thing the 6.0 will be choked out up top. But its over all size I could make fit pretty easy. Budget wise its at the very top of what im willing to spend on just the turbo. building the kit for pt7675 I could probably keep the stock condesor and modify the top ac line.
down fall is if I ever want to upgrade to a larger frame chances are ill have to modify my turbo kit, something im trying to avoid.
s475 budget wise is really killing me cause its cheap and proven! Especically when I have the 6.0 with a tick custom cam. And if I ever wanted to upgrade my turbo kit would already have a t6 flanged. Down fall is building the turbo kit will be tricky with keeping ac and fitting that huge turbo in there. If I go with the s475 ill prob have to buy an aftermarket condensor and to custom ac lines to clear everything.
Really dont want to spend more then $1200 on a turbo. I guess options are shell out for a better "packaged" turbo or save some money on the turbo and go s475 and spend more time/money making it fit my needs.
Whatcha think? Ive tried emailing forcedinductions with no response. Called and talked to him for a minute but could hardly hear him.
