What pumps are you E85 guys running?
Old 10-29-2013, 06:54 PM
adrynalinjunkie's Avatar
Default What pumps are you E85 guys running?
I have a LQ4 that I am going to run a S88 Turbo on in my 67 Chevelle, I need advice on QUIET fuel pumps that will last on E85.
I just returned a 4303 to Summit after reading about how loud they are.
I am leaning toward dual pumps mounted in my fuel cell,
What pumps would be the quietest and handle the E 85 on the street the best?
I am looking for somewhere around 800 rwhp, but I will probably turn it up when I get there.
Old 10-29-2013, 06:58 PM
samdogmx's Avatar
holley dominator 1800
Old 10-29-2013, 07:04 PM
smokeshow's Avatar
Twin walbro 450s in my tank, sounds stock. Though some people have reported them being loud and noticeable.
Old 10-29-2013, 07:12 PM
silver_82's Avatar
Right here. I totally agree.
I use a walbro 255 and an aeromotive eliminator, works great but I had to buy more filters/fittings/ and a $75 check valve so pressure wouldn't back feed through the eliminator.
Wish the holley pump was available at the time I was putting mine together. I would have bought it instead. A friend uses the holley 1800 and its quiet and compact
Old 10-29-2013, 07:45 PM
samdogmx's Avatar
the holley replaced an old aeromotive A1000 I had in the car & Im not kidding when I say it was so much quieter I had to double check it was running.
Old 10-29-2013, 07:58 PM
And Holley gives its blessing with E85? 100% compatible?
Old 10-29-2013, 08:29 PM
OK I am sold what regulator should I run?
I have read great things about fuel lab regs any other ideas?
Old 10-29-2013, 08:36 PM
CameronVic's Avatar
Magnafuel 625. I enjoy the noise.
Old 10-29-2013, 09:38 PM
silver_82's Avatar
Yes sir
Old 10-29-2013, 10:25 PM
skinnies's Avatar
I run 3 internal walbro 255's in my ltd, you can't hear them at all outside the car. The bosch 044's on my mustang you can definitely hear, nothing like a 4303 though.
Old 10-29-2013, 11:20 PM
DropShipDave's Avatar
You can do dual 340lph's too
Old 10-29-2013, 11:32 PM
foose04's Avatar
They are quiet in my opinion. Running a 60PSI base, I'm dropping pressure bad at around 1k wheel HP. (bad is 1-1 reference and pressure is down to 65 at 22psi boost and small 50 nitrous pulling off the top)
Old 10-30-2013, 04:55 AM
73turbo53's Avatar
Yes holley all the way, its extremely quite, small package, and cheap compared to runnning individual pumps.
Old 10-30-2013, 07:17 AM
408GT's Avatar
Belt drive? Real quiet and support all the power you could make!
Old 10-30-2013, 07:19 AM
00Wildcat's Avatar
I too run and recommend the 1800 Holley, although at 160 trap speed and 3550# I'm out of volume
Old 10-30-2013, 07:48 AM
dmaxvaz's Avatar
what size injectors?
Old 10-30-2013, 10:08 AM
Sarg's Avatar
My eliminators pretty loud, but can't hear it over the exhaust
Old 10-30-2013, 10:23 AM
1INSANEGTO's Avatar
Walbro 267's
Old 10-30-2013, 11:03 PM
00Wildcat's Avatar
cheapie FMC whitetop 160's
Old 10-30-2013, 11:24 PM
janks300's Avatar
magnafuel protuner 750... its a little loud but i cant hear it when the car is running.... imo continuous duty, high horsepower and e85 is a tough combination....
Quick Reply: What pumps are you E85 guys running?
