Lightweight DIY vertical FMIC mount for 4th gen F-Body (No welding required)
Old 10-30-2013, 10:04 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Default Lightweight DIY vertical FMIC mount for 4th gen F-Body (No welding required)
I was a bit tired of my stock front end and decided to go ahead and just ditch my horizontal FMIC setup and show off the intercooler through the front license plate opening and the fog lights. So, I set out to make my own mount. Only, I don't have a welder and I did not want to hassle someone else to weld it up for me. Being an aerospace design engineer, I design parts for a living that use fasteners in lieu of welds, so it is no surprise that this is what I came up with..
For materials, I chose aluminum for its light weight and ease of cutting. The whole project can be done by buying a 1"x1"x8' square tube, and a 2"x2"x8' angle stock, and of course some hardware- which I used 1/4" screws & nuts- 2 lengths: 1-1/2" and 3/4".
The whole setup is essentially two brackets- one bracket to attach to the car, and one bracket to attach to the intercooler.
For the first bracket that attaches to the car, cut 2 pieces of tube to fit across the front of the frame horns and mount them as shown here:
Next, Cut 4 legs to hold out the intercooler the desired space from the frame horns, and then attach those angles with a vertical angle:
You will need to trim the bottom angles to fit under the intercooler as shown here:
Once you have your vertical angles attaching the legs holding the intercooler, measure the distance between them, and then attach vertical angles to the tubes at the same distance:
Now remove the brackets that hold the intercooler and attach them to the vertical angles on the tubes:
*NOTE* Do not attach them as low as shown here- space them 1" up from what is shown in this pic, you will see why later..
Here is a pic of everything mounted up. You can see how I have started to make some 45° cuts on the driver's side bracket too.
And here it is with the intercooler mounted:
I removed it from the car to redo my piping, so I got a few pics of it off the car too:
Here is a pic of one of the frame horns where I drilled the mounting holes:
And now, on to modifying my old pipes to accommodate the new mount:
Again- I do not have a welder, and I did not want to bother anyone to weld new pipes, so I just ordered some straight hose from the same place I ordered all my other silicone parts for my piping- siliconeintakes dot com. Great place for DIY systems!
And here is the other side after the same method:
As you can see, the intercooler sits out about 8-7/8" away from the front of the frame horns:
Here is a pic with the mount and the piping. Ready for the intercooler (at least I thought anyways)
Remember when I said earlier to space it up 1".... Here is why. After I put the bumper on, the lower angles were protruding out below the bumper by a little bit.
So, learn from my mistake, do it this way the first time around:
^^*Note the close proximity to the top angle and the top of the bumper cover in the above pic*^^ Don't think I could have gone up any more if I had wanted to!
Now this is much better:
Now cut the fog light buckets as required:
I cut mine 9" from the front of the frame horns which left a nice little 1/8" gap for clearance. You can see the gap here:
And now, the finished new look:
Old 10-30-2013, 10:07 PM
ChevyChad's Avatar
Oh, BTW, the mount itself only weighs 67 oz total with all fasteners. That is just 4.19 pounds
Old 10-30-2013, 10:48 PM
conan's Avatar
Looking good, Nice work.
Old 10-30-2013, 10:56 PM
sbcgenII's Avatar
Are those locking nuts?
Old 10-30-2013, 11:11 PM
wicked z28's Avatar
Are you gonna start selling this intercooler mount?
Old 10-31-2013, 05:31 AM
ChevyChad's Avatar
Actually, they are not. It would definitely be better to use locking nuts tho.
No plans to sell it. Would defeat the whole purpose of DIY lol. Seriously, anyone can make this. All you need is a drill and a grinder with a metal cutoff wheel. Total cost for all the materials and hardware was less than $70.
Old 10-31-2013, 07:22 AM
ramairetransam's Avatar
im driving down to savannah to have you make me one for my formula .
looks good . i need a fmic .
Old 10-31-2013, 08:46 AM
MUSTANGBRKR02's Avatar
I came in expecting to see a verticle mount IC. You could swap those bolts for rivets and shed some weight to. Looks good but it is a horizontal.
Old 10-31-2013, 08:51 AM
SPRAYED 01's Avatar
Very coolv thanks
Old 10-31-2013, 08:54 AM
ChevyChad's Avatar
Horizontal would make it parallel to the ground man.. Been there, done that. Check out my link in the first post
You are right about the rivets though. But most people don't have a rivet gun..
Old 10-31-2013, 09:28 AM
gpr
gpr's Avatar
You will have to let us know mounting position has lower IAT's. Other than seeing the intercooler were there any draw backs to the horizontal mounted intercooler?
Old 10-31-2013, 09:47 AM
ChevyChad's Avatar
My coolant temps seem to be a bit better with this setup, but then again, its hard to do a direct comparison since last time I was driving it regularly it was in a different state and a different time of year lol... IAT comparisons would be just skewed due to different environments, so I really cant offer any scientific insight to that inquiry...
Old 09-29-2014, 04:18 PM
locospl's Avatar
So I can find this later
Old 12-06-2016, 08:20 AM
Darkness1982's Avatar
Do you have any info on what pipe, and rubber couplings, etc. that is needed to accomplish this setup? I currently have the twin FMIC on my 2001 SS and want to change to a front mount. Did you reuse some of those fittings or just buy all new?
Old 12-06-2016, 01:16 PM
93camaro_zzz's Avatar
Why the hell are you spending time turboing this transam, instead of turboing that GTM in your sig. Thats what I really want to know.
Quick Reply: Lightweight DIY vertical FMIC mount for 4th gen F-Body (No welding required)
