FAST 90 vs LS6 on boosted ls1
I've did alot of wondering over the last year about the best intake for a boosted aplication and if it mattered much as to what intake was on the car power wise for a street build. The car is a 99 SS with a stock bottom Ls1 with cam, full bolt ons ect with a D1 Procharger. It had a FAST 90/90 on it up untill the other week when I swapped it out to a Ls6 intake and stock "ported" TB. The car made 638/538 to the tires with the FAST combo. I just dropped it off yesterday with the tuner to get it dialed in with the new intake. I will post the new numbers as soon as I get word.
Any gueses as to how much power it will lose with the Ls6/stock TB over the FAST? Im guessing it makes 625 now but could lose none. Im curious to see. It is the exact same setup otherwise other than I removed the AC.
how are you making so much , i have a friend with a d1 on his 00 ta with a cam and that made 550 with meth and twin 4.5 intercoolers.
I just made 499.4 with stock cam , lontubes , ls6 intake and a p1 making 10 lbs .with meth .
how are you getting over 600
stock motor with custom grind cam
1 7/8" TSP headers
TSP true duals
ls6 intake (now)
D1
Front mount IC
4.25" blower pully (about 11.5# boost at 6500rpm)
Truck hat with big K&N filter
m6 with 9" out back
That pretty much covers it
The dyno is a Dynojet for what its worth
Same dyno etc ?
It will certainly be interesting results, although would have been great for before/after on same day
I'd say no change, but look forward to the results. It really is one test that nobody seems to have documented !
Yes same dyno and same exact setup as before down to the rear wheels/tires, timing and all. Only differance is the removal of AC and of course the Ls6 intake.
Im running a t4 comp ct5/43 hybrid. Its a ct5 mid frame with the smaller ct43 compressor cover. About the size of a pt88.
88mm billet comp wheel and 94/88 turbine, triple ball bearing. Spools instant on my 370 and 3600 stall combo.
Sir, I have done 2 pulls with ur car. It has made 632/535 with the same tune it had and it is out of fuel pump hardcore now after 5800 rpms.
I was just sent this. Sounds like its making more power with the FAST intake. Looks like fuel system time.
