Datsun 280z Turbo Build - 5.3 / T7875 / Magnum T56 - Video on page 12!
Old 11-13-2013, 11:29 PM
8 Second Truck Club
Blown06's Avatar
Maybe I'm looking at it wrong. What is the deal with the down pipe having to transition down and then right back up?
Old 11-14-2013, 05:55 AM
STEEPSS's Avatar
The outlet on the turbo is a 3" V-Band.
Old 11-14-2013, 07:32 AM
MIGHTYMOUSE's Avatar
if you run into tight spaces with that 4" pipe a 3.5" would serve you just as well and weigh/cost less.
Old 11-14-2013, 07:47 AM
STEEPSS's Avatar
I wish I'd known that before I bought all this junk!
I'll keep that in mind. I should be OK once it gets unde the water pump. I plan on transitioning the 4" into my 3" duals that are already on the car, and possibly putting a cutout in there as well. Though, I'm not sure if I would see any gains? (Other than noise)
Old 11-14-2013, 07:52 AM
ajrothm's Avatar
KILLER CAR!!
Pretty much my dream build for a killer street car.. I love everything about it.
My only recommendation for you is put a power glide in it now.... It will be way faster and not break near as much stuff..
As light as that car is, with 800-900 rwhp thru a glide, it would run 8.50s... Still be very streetable.
Sub'd.
skinnies's Avatar
At your power you don't need the cutout, dual 3" will flow way more than enough.
Old 11-14-2013, 08:18 AM
RedRocketZ28's Avatar
I think someone told you that BEFORE you bought all the piping...
Old 11-14-2013, 08:59 AM
STEEPSS's Avatar
Nooooo, you said 3". You need a new DP anyway don't you? Maybe I'm starting to build yours lol.
Old 11-14-2013, 09:11 AM
3" or 3.5" was my suggestion. My car seemed to do ok with a 3".
I WILL need some 4" pipe for the new setup, but not sure where the turbo will be placed.
Old 11-14-2013, 09:34 AM
thats what happening with ls1tech.
everybody running dual 4" bullhorns out the front bumper of their daily driver SMH.
in that car you can go 7's with a single 3.5" exhaust.
Old 11-14-2013, 10:47 AM
STEEPSS's Avatar
Haha, so true. Every time I get on here my build changes direction. Case in point ^
Old 11-15-2013, 12:02 AM
  #32
8 Second Truck Club
Blown06's Avatar
I was looking at it wrong. Thanks.
Old 12-02-2013, 02:13 PM
  #33
Trl_ws6's Avatar
any updates?
Old 12-04-2013, 06:07 AM
  #34
STEEPSS's Avatar
Car has taken a back seat to finishing my garage. Hope to have HEAT in the next week.
Made a slight bit of progress on the car though. Built a wooden fixture to mount the turbo where I want it. Now all I have to determine is height. Cut a hole in the OSB, bolts from the bottom up, two nuts on top of OSB (to clear compressor housing), then the transition and turbo are set on and bolted down.
This will allow me to take the turbo off and out of the way to build a majority of the hot side
Old 12-04-2013, 08:14 AM
  #35
aknovaman's Avatar
Propane bullet heaters work great, if you are still at the same place as last time i was there.
Old 12-04-2013, 08:59 AM
  #36
STEEPSS's Avatar
Negative. I have a house now.
Old 12-04-2013, 09:45 AM
  #37
oscs's Avatar
Get to work on that lower radiator support. I'm curious what you are going to do. I cut my upper out last week, just waiting on the motor to get back so I can start mocking everything up.
Old 12-04-2013, 09:48 AM
  #38
oscs's Avatar
Originally Posted by oscs
get to work on that lower radiator support. I'm curious what you are going to do. I cut my upper out last week, just waiting on the motor to get back so i can start mocking everything up.
Datsun 280z Turbo Build - 5.3 / T7875 / Magnum T56 - Video on page 12!-image-2870770649.jpg
Datsun 280z Turbo Build - 5.3 / T7875 / Magnum T56 - Video on page 12!-image-3837716808.jpg
Old 12-27-2013, 12:38 PM
  #39
AmishAssassin's Avatar
Default Moar!!!!!!!!!!!!!!!!!
Is this thing going to be on 1320 video this year? I would like to see you go up against the *****'s! Updates?
Old 01-03-2014, 08:12 AM
  #40
STEEPSS's Avatar
I'm sure it will make an appearance.
I've been out of the country / state for the last 3 weeks. Hopefully I'll get back to it this weekend, after my garage is heated!
Quick Reply: Datsun 280z Turbo Build - 5.3 / T7875 / Magnum T56 - Video on page 12!
