S480 on a 427?
Old 11-08-2013, 06:54 PM
knuts82's Avatar
Default S480 on a 427?
Would a Borg s480 1.32 T6 be large enough for a 427LSX
And be able to push a 3000lb. Foxbody into the low 5's in the 8th
I also have a set of On3 76's with .96ar Turbine housings I could use but kinda want to do a single on this one.
Thanks
Old 11-08-2013, 07:44 PM
dans94z28's Avatar
Think that borg warner would be much more efficent than the two smaller ones.
Old 11-08-2013, 07:49 PM
dans94z28's Avatar
Im sure you could get a cam designed to help it be even more efficent also
Old 11-08-2013, 08:34 PM
dmaxvaz's Avatar
Thanks
i would do twin s366's with billet wheels from Forced Inductions. 66mm comp wheel, 74mm exh wheel, and .91 exh housings. throw those on3's away.
Old 11-08-2013, 08:49 PM
knuts82's Avatar
I was just thinking the same thing after reading some more posts.
Quick Reply: S480 on a 427?
