My 69 Nova L33 S476 project (Finally Some Runs)
#461
I hear ya on the wiring, life used to be so simple in the old days, then GM made it simpler with the HEI, then it all went crazy, lol
I use a #4 wire alt to bat when I run a trunk bat
if your FP is rising 1-1, might give you an idea of boost accuracy
good first outing, plenty left
#463
Good to hear you made it to the track and have already overcome the wiring issue. I decided to move my battery to the driverside just becuase of the NHRA rules and external cutoff switche's...such a pain to keep everyone happy. When's the next track outing gonna be?
#464
Hey, agree it's a pain. And after driving for a bit, I'm not convinced I have it completely fixed yet.
I absolutely have to have the trans shifting before the next try. That was frustrating. And I'll run the slicks.
I added VSS to my TH400. This will help the drive around stuff a lot.
So maybe in a couple of weeks?
Ron
Ron
#466
But but, think of the weight! Ha!
I thought about the L80, but just wasn't in the budget.
I fixed a couple more nagging voltage issues. Now I'm looking into what I need for check valves for the vac modulator line. I'm tired of spending money on this. The transgo valves are $40 by the time you ship. Jake says I need two.....
There has to be a cheaper solution. Perhaps the Treadstone check valves?
#467
Restricted User
Use a brake booster check valve. The vacuum modulator line is about the same size as most brake booster hoses. You could probably scavenge a few of them pretty cheap. If they're OEM, they're reliable enough to keep your power brakes working. I don't see you having an issue with them in this situation.
#469
I have one of the Transgo ck valves when I built a man shift 80E
pretty simple thing, but I switched back to full auto, got old
I kind of preferred full auto on the 400's with boost, but a ck valve could work
back in the day B & M had a mech like vac. mod when they were selling blowers, I don't know how it worked though
I found a brass ck valve thru NAPA that I used on my PCV valve, so I didn't blow boost back in the engine-theirs a ton of diff valves out there, how much boost they can hold is trial & error
keep spending money, your Gov. needs it for something, I just don't know what, lol
if I can find my valve your welcome to try it
#470
http://www.ebay.com/itm/260134015180...#ht_1987wt_940
#474
after thinking about this some, a ck valve in the vac line wont work, it will always have the mod. in a vac. state since there is no way to be exposed to the atmosphere (look at what happens when you rem the line to power brakes, vac still there)-prob burn up the clutches with reduce line pressure?
could be the reason Jake said it needed 2 valves
I was looking at the transgo one last night, its just a plastic tee with a short hose, brass tube with a ck ball-prob under boost it pushes the ball off the seat to release some boost, although some can prob still get to the mod
seems like under boost it would be like a small boost leak, prob not enough to rob power, lol
#480
There is an orifice about 1/16" or so to limit the amount of boost that enters the device to begin with, so the check ball doesn't have to bleed that much boost to begin with.
