overboring a 6.0 to 4.065
Old 11-10-2013, 04:13 PM
toughy v8's Avatar
Default overboring a 6.0 to 4.065
I know plenty of you will say no but Can someone explain what the actual issue is? I have some Caddy lsa pistons im wanting to use but short of buying an ls3 block I dont know how else im gonna use em.
Old 11-10-2013, 05:29 PM
9 Second Truck Club
stock48's Avatar
Would be a good idea to sonic test the block first. The iron 6.0L blocks have thin cyls. I have 11 blocks in my shop and thickest one is .155" between cyl wals. Thinist is .089". Not only can they split cyls when thin they don't stay round lose ring seal.
Old 11-11-2013, 01:37 AM
toughy v8's Avatar
So would filling the block help
Old 11-12-2013, 01:45 AM
9 Second Truck Club
stock48's Avatar
Filling wouldn't hurt but best thing would be a sonic test. I just saw an article where that 408CI twin turbo pinto that runs high 7's split a cpl cyls in same exact place. He was making a lot of power but I doubt it was +.065'' over. Even for a lower HP or NA deal I would still sonic test it. The thin block will usually show up on the hone.
Old 11-12-2013, 09:46 AM
c0ncEpT's Avatar
You can do it but its not recommended. I have been selling a lot of take out LS3 pistons on Ebay and I know for a fact there were a few guys buying them to make budget 6.2L engines out of 6.0L truck blocks.
Like stock48 said the block should be sonic checked as the cyl walls will be getting very thin @ 4.065
Old 11-12-2013, 11:06 AM
1CAMWNDR's Avatar
fill it to the water pump ports and it should be fine for normally aspirated only. Mine is 4.07".
Old 11-12-2013, 02:24 PM
toughy v8's Avatar
Its for a turbo build im wanting to use my lsa pistons with a 4.8 crank and rods.
Old 11-12-2013, 06:28 PM
Z-Gad's Avatar
I concur on the thin walls on the 6.0 blocks. My machinist sonic tested mine before the build, and it was only .060 in the thinnest area of the cylinder wall. I ended up buying a new GEN IV iron block from Chevrolet and the thinnest wall he could find was .220 !!
What a difference ...
Old 11-12-2013, 07:30 PM
1CAMWNDR's Avatar
I would not do it then. Get a 6.2L block. If I had it to do over, I would not worry about having a 4.07" bore/4.100" stroke near 427" engine. I would have stopped at a 408".
Old 11-12-2013, 07:42 PM
9 Second Truck Club
stock48's Avatar
If it's a Gen 4 iron block like staited above and measures thick It would be fine. I have no experience with the iron Gen 4's all my blocks are gen 3's. Kinda makes you wonder about the alum blocks that are .500" of alum vs .100-.150" cast iron.
Old 11-13-2013, 08:27 PM
TurboS10's Avatar
Its for a turbo build...
Then just build a 5.3 or some combination of that size.
Sounds like your trying to pc together left overs.
With the price of a 5.3 it really isn't worth the hassle.
Turbo selection will make a bigger difference than bore size.
Quick Reply: overboring a 6.0 to 4.065
