Need help keeping engine cool.
Air-dam doesn't make a difference if it's overheating at idle.
Does it cool well at speed? If it does, the radiator is probably fine and you need better fan(s). My radiator is tiny (17x17x3.5) and cools my turbo 5.3 on 100* days no problem with a ford Taurus fan on the high setting. Usually leave it on low. Has large front mount IC in front of Rad as well.
This is before I glassed the ends and mounted it but you can see it doesn't take a massive radiator if you have a good fan/shroud setup. I believe these flow 3600CFM on high and can be picked up for around $50 used. Use 2 30a+ relays for the high setting.
my radiator sits slightly below the water pump, maybe i just have a ton of air in the system? it doesnt overheat just sitting there, but it sure as **** gets HOT HOT HOT sitting there, the fans dont cycle at all... they are on high all the time.
Are you running the factory ps cooler, if so ditch it. What works for be were the dual shrouded pullers from an 01 saab 93 turbo. Search my name I made s thread a few months back.
What fans are they? I see an a/c condenser as well. Is there anything clogging it up from flowing air past? I have the derale pushers and don't get over 205*. Your fans shouldn't come on while your going down the highway either. The natural air flow should be enough to cool it. That's where the air dam comes into play. Do you have the crash bar removed in the front? If you have these done already and a good set of fans, I'd lean towards air in the system or a bad waterpump/thermostat.
As mentioned previously, the Taurus fan is awesome. I had it on my single setup and it wouldn't go over 190 in the southern heat. However it's massive and takes a huge relay.
I forget what fans I have, but they are flexlight (sp?) pullers...
when I check my coolant level, it is topped off, if there was air in the system, after a few heat cycles, wouldnt it work its self out?
I have a 180 degree tstat, i just got a new 160 in, i am going to install that
the condensor is new, and does not get warm as it is not hooked up.
On a cool night, going 60mph in 6th gear, it stays at 200... ****, maybe my tstat IS not working?
These cars are a bitch sometimes to get all of the air out of the system if you just search how to remove air you will see what others do to fix that problem. T stat could not be opening because of the air also. Id try that first. One way is remove the upper hose going into the water pump fill that up till with radiator cap off then connect it back on. Start it up squeeze both hoses at least 20 times while its warming up you should see some air bubbles come out of the radiator and after just throw The cap back on. See if that works
You need a "spill free" funnel to burp it properly. Jack the nose up a little and do this.
If the heater is hooked up make sure you heater is running on high.
