Which LSX configuration is preferred for medium hp daily driver?
Old 11-20-2013, 10:49 AM
RonA's Avatar
Default Which LSX configuration is preferred for medium hp daily driver?
After purchasing an LQ4 core that was scrap, I've decided to cut my losses and just get an LSX block built up. There seems to be a lot of opinions as to displacement and which bore/stroke combination to go with. For a durable, medium hp (around 800rwhp), turbo motor with good drivability in a 3300lb car, what do you guys like? Short stroke(3.25"), medium(3.625), or long(4")? 4" bore for wall thickness, or 4.125" so you can use larger valves? Just curious what people have tried that worked well and lasted a while.
Old 11-20-2013, 12:28 PM
F110Mech's Avatar
LSX block for 800 rwhp? Most guys seem to have luck with factory blocks at that HP level
Old 11-20-2013, 12:36 PM
HexenLord's Avatar
My engine and full turbo setup cost me less than a bare LSX block, and I have the same end-goal as you. Hell, a stock 6.0 bottom end has been into the 8s.
I wouldn't even consider an LSX block until I needed a reliable setup for serious bracket racing. Unless you've just got money pouring out of your wallet (in which case... hey my Nova needs a new paint job..), then save yourself the time/money.
Old 11-20-2013, 01:08 PM
RonA's Avatar
If you don't mind what's in the engine compartment, Krylon should be fine for the outside.
Old 11-20-2013, 01:40 PM
dmaxvaz's Avatar
i would do a 427 ci (4" stroke/4.125" bore) ls7 heads or gmpp 6 bolt heads with twin s366s turbos.
Old 11-20-2013, 02:41 PM
HexenLord's Avatar
Seeing as how my last Mustang ran low 9s on less than you're going to spend on your bottom end... you sure as hell better have something other than an expensive disappointment planned.
Old 11-20-2013, 03:02 PM
stevieturbo's Avatar
What vehicle, what usage, what transmission, what fuel, what rpm range do you use etc ?
Really, there are dozens of engine configurations that can make that power goal reliably....but are they all the same, and suited to all applications ? Maybe not.
Old 11-20-2013, 04:24 PM
RonA's Avatar
I got a recommendation and quote from a reputable shop. Medium sized, compromise between short stroke and long. No sense over thinking this. Thanks for the replies.
Quick Reply: Which LSX configuration is preferred for medium hp daily driver?
