First turbo build Pt88/4l80e/ac
Old 08-20-2014, 09:06 PM
  #101
kylemm1002's Avatar
Push lock wtf. I'm bored searching for pics of dual pumps in stock buckets so here is a pic lol
Old 08-21-2014, 08:34 PM
  #102
kylemm1002's Avatar
Just some pics of the manifold coming together. Clears the alternator and throttle cables just fine.
Just need to find some motivation to get my dual pumps installed...
Old 08-22-2014, 07:16 PM
  #103
kylemm1002's Avatar
Thanks to Mighty Mouse for getting this out ASAP!
Old 08-23-2014, 12:27 PM
  #104
samdogmx's Avatar
get this thing tuned and running already.
Old 09-03-2014, 03:31 PM
  #105
kylemm1002's Avatar
It runs and drives....missed this view.
Old 09-09-2014, 08:01 PM
  #106
kylemm1002's Avatar
Well after driving the car a total of 5 miles I was worried leaning on it would hurt the Trans. It shifted great but fluid didn't look promising even before the turbo was installed. I decided to quit while I was ahead and yank it out last minute...
Good thing I scored a fresh gm reman 4l80e for a killer deal I couldn't pass it up. Already ordered most of the swap parts. Plan on using the stock Trans/converter until next year when I get it fully built. Figured a stocker shouldn't blink at 7psi! Just need to figure out what yoke I need still! It will be back together this weekend I hope.
Anyone that has 4l80e swap advice let me know!
Also installed a new blanket. Ebay special but I must say it fits pretty well have to wait and see how well it keeps the heat in! (Ya I know I need to clean up the cut on my core support, I was in a hurry lol)
Old 09-10-2014, 08:24 PM
  #107
kylemm1002's Avatar
First 4l80e swap part showed up today.
Bmr conversion cross member.
Still need to find out if I can reuse my stock 60e poly mount.
Old 09-10-2014, 09:34 PM
  #108
transam69230's Avatar
Yes you should be able to use the 60E mount, I did.
Old 09-11-2014, 10:04 PM
  #109
kylemm1002's Avatar
Thanks. Used the 60 mount just fine.
Seems a little more trimming is in order tho. Not enough room for the plug and no where near enough room for the AN adaptors for the trans lines.
There won't be much of this tunnel brace left when I'm done! Lol. Already had this thing in and out 3 times. Hopfully tomorrow after one last adjustment it will be in to stay.
Comparison pic just because.
(Yes I'm aware the 80e is missing the 12 o'clock mounting hole! That's why I got such a good deal!)
Old 09-21-2014, 10:13 AM
  #110
kylemm1002's Avatar
Well after installing/removing trans about 4 times to check all my clearances it's IN!
And runs and drives. I'm using the stock drive shaft for now and a conversion u joint. I'll have new drive shaft made when I swap rears down the road.
Car is done for this year. It's getting tuned in the next day or so and will hopfully be ready to rock by Tuesday evening. All I have to do is some small stuff to make it 100% this go around. I'm very happy with the way everything fit and came together. I'll be posting some cleaned up pics and vids soon! A group of friends and about 40 cars is headed to a show this weekend and I'm glad the car will be there!
Old 09-22-2014, 04:32 PM
  #111
Spectre86's Avatar
Originally Posted by kylemm1002
Ok so I have some questions on wiring for both battery relocation and fuel pumps. Goal is to run all my wires once so I don't have it rip the interior apart again.
Battery
1/0 from battery to switch
1/0 from other side of switch to starter
4gauge from starter to fuse box
4gauge from alternator to battery
All new grounds from block to frame and battery to frame
For the fuel pump I was thinking a harness like this
http://www.racetronix.biz/itemdesc.a...%2D001&eq=&Tp=
Questions
Since my battery is in the back can I run the power for my pumps to the opposite side of my cut off switch in the rear? (Saves me from running 2 10gauge wires all the way up front) or is that a bad idea?
I plan on using a Hobbs switch to activate the second pump. Plan to mount that up front so what gauge wire should I run from the Hobbs switch back to the relays? (relays will be mounted in the spare tire well).
badass build man. what are you running for a dual pump setup? What else was needed besides that harness?
Im looking at running dual AEM 320s that are E85 friendly, and not sure what else was needed.
Old 09-22-2014, 06:51 PM
  #112
kylemm1002's Avatar
I ended up buying ractronix dual 340 fbody pump kit. Came complete with dual harness everything I needed. A little bit of time with an ohm meter figuring out the new bulk head fitting had it working great.
Old 09-22-2014, 08:23 PM
  #113
Spectre86's Avatar
What pumps come with that kit? Are they aeromotive?
Old 09-28-2014, 06:21 PM
  #114
kylemm1002's Avatar
Installed the new trim ring.
A few pics from a show we attend in Springfield IL. We took about 40 cars this year.
Had a few good runs and for being on such low boost I'm impressed. A set of tires and boost controller will be top of the list for next year!
And I'll try to get some vids tomorrow!
Old 10-01-2014, 12:58 PM
  #115
DramaBull's Avatar
Since you are running it off the waste gate spring what spring is in it?
Will you be going to the track to get a time on it before the track closes for the season?
Old 10-02-2014, 09:45 PM
  #116
kylemm1002's Avatar
It's got a 7psi spring in it now. Makes 5psi. Not sure about the track. I might make it but probably not
Old 10-03-2014, 11:59 PM
  #117
Kmspeedie's Avatar
i love your build man!great work so far..justa couple questions..i havva stock ls1 witha single 7575 and been wondering about swapping to a pt88 when i put my forged ls1 in..but my 7575 witha 3400 converter spools up nice and quick on the street and im also auto..how quick does this thing spool up on the stock motor? i just dont want to much lag on the street..i love giving it a lil gas and u can hear the turbo spooling
Old 10-04-2014, 06:50 AM
  #118
Heavy H.P.'s Avatar
Im curious how quick it spools my self.
Old 10-04-2014, 09:55 AM
  #119
NoorJ's Avatar
lookin good man! your hotside looks really clean. how loud is it dumping out the fender? I'm wondering if I can do that but I still want to daily the car
Old 10-04-2014, 02:33 PM
  #120
kylemm1002's Avatar
It's not terribly slow to spool but it's a little lazy. About 3600-3700 it's on 5psi. My problem is I'm using a stock converter. I think with a purpose built stall it would help a TON! Pretty much as soon as I get into boost the gate opens at the same time lol.
With the bumper exit exhaust it isn't that loud at all. Quiet while I'm cruising down the highway. Other local H/C/I cars with long tubes are louder then my car. That being said if it was a daily no way I would do bumper exit down pipe. I like my daily quiet tho.
Quick Reply: First turbo build Pt88/4l80e/ac
