Need some help on my 408 build
I'm building a 408 stroker right now that I will be running the F1-X Procharger on. I have the bottom end complete minus cam. New 6.0 Iron Block from Summit bored .030, Lunati Crank 4.00, Lunati Rods 4.125, JE Dish Piston -28cc, Top Seal File Fit Rings, Clevite Tri-Armoured Bearings. What cam and heads have you all had best luck out of for power on a Procharged build? This engine will be ran on 93 pump gas with or without meth injection haven't decided yet somewhere between 16-20psi. Please let me know =)
Thanks, Wes.
Thanks, Wes.
8 Second Truck Club
I'm running a very similar combo right now.....except with an F2.
I'm using some Edelbrock 245cc cathedral heads originally cnc'd by wcch. They were gone through and touched up by Greg G. and everything was set up for a solid roller.
The combo make a ton of power. What are your goals?
