injector for 5.3 truck manifold
Old 11-27-2013, 07:33 PM
x275radial's Avatar
Default injector for 5.3 truck manifold
looking for a set of 60lbs injectors that will work in my truck manifold. not sure which ones to order.
Old 11-28-2013, 02:18 AM
Moderator
denmah's Avatar
i would suggest getting siemens deka 80s, i use them for everything, they are approx 300-350 dollars, very flexible and usually the same price as 60s, so why not just get the extra leg room in case you want to grow.
also i have used them in nearly every project i have built and i cant say anything bad about them.
you can get them from basically any site sponsor, ebay, lethal performance etc.
what year truck? i always space up my rails to accommodate the larger, taller injector, no problems
Old 11-28-2013, 08:39 AM
ezstriper's Avatar
we run a truck intake...better off changing the rails, intake is fine..
Old 11-28-2013, 10:14 AM
x275radial's Avatar
It's an 01 5.3 out a Tahoe. Thanks for the reply does anyone know if they can be bought from jegs I have a credit with them otherwise ill order them from leathal
Old 11-28-2013, 10:16 AM
x275radial's Avatar
Also what rails fit the truck manifold. I own a machine shop so if I need new brackets or what ever I could make them up.
Old 11-28-2013, 10:42 AM
x275radial's Avatar
I was looking into the edelbrock 60lbs injectors. ive decided to keep the stock rails for now cause my fuel system is already done
Quick Reply: injector for 5.3 truck manifold
