Boosted aluminum 5.3??
mine is the l33 aluminum. will be upping the boost shortly.
http://forums.corvetteforum.com/c5-f...o-results.html
Aluminium is lighter, it has thick cylinder walls, it is very strong, it is light and they're still very cheap.
That's why so many people are now using them with boost.
I would guess the 850-900whp range is where you will need to consider forged internals. I have a L33 short block being assembled with weisco's and eagle rods now and I will push my stock short block until it pops on E85 and a larger turbo in the spring. then switch.
Mine is completely stock cam, springs, head studs, and gaskets only. I made 20-25passes this year and went 8.76@156 with mine. They are the ****.
