another turbo 5.3 s10 on the way
thanks to you guys i finally pulled the trigger and ordered my stuff.
heres the combo
1998 s10
mono leafs
caltracs
275 drag radials
calvert shcoks all around
motor 2001 5.3
862 heads
truck intake with stock rails for now
truck throttle body
ls6 head gaskets
gm performance .550" cam
ls7 lifters
7.400 comp push rods
trunion rocker kit
double roller timing chain
pac valve springs
arp head bolts
siemen 80# injectors
aero 340 stealth intank pump
hp tuners
2 bar map sesnor
tc78 which i scored brand new for 650 bucks
tial 44mm wastegate
tial 50mm bov
fmic
ford 8.8 narrowed with spool and 31 spline moser axles
3.73s for now gonna try them first
turbo400
ucc converter
thanks ls1 tech
any idea what this pile should make at 14psi
heres the combo
1998 s10
mono leafs
caltracs
275 drag radials
motor 2001 5.3
862 heads
truck throttle body
ls6 head gaskets
ls7 lifters
trunion rocker kit
pac valve springs
arp head bolts
hp tuners
2 bar map sesnor
tial 44mm wastegate
tial 50mm bov
fmic
turbo400
ucc converter
thanks ls1 tech
cross over is being built in 2 1/2 stainless. i wanted to do 2 1/4 but i had to much 2 1/2 material in the shop so i decided to use it. will post pics as soon as i figure out how not much of a comp guy. doing a full body off on this thing. painting the frame and everything.
