New Build TT LQ4 for 78 Malibu
Old 11-30-2013, 01:32 PM
xsivpwr's Avatar
Default New Build TT LQ4 for 78 Malibu
New to this forum and new to building LS engines. What better way than to start with a Twin Turbo build. This will be going in a 78 Malibu, built to drive daily.
LQ4 (317 heads)
Turbonetics 66/62
Hi-ram
Cam--? I will need someone to spec one for me(im ready to order), (im picky about drivability and spool time)
Stock Ecu - I have efi Live but will need help tuning this(anyone have a base tune for purcase?), my experience has been with the BS3 only.
Trans is a 4l80
fabrication is coming along, just finished with the coil mounts.
Any feedback is appriciated...
Old 11-30-2013, 01:52 PM
xsivpwr's Avatar
figuring out how to add pics... oops
Old 11-30-2013, 01:54 PM
xsivpwr's Avatar
more pics
Attached Thumbnails New Build TT LQ4 for 78 Malibu-20131129_224355.jpg   New Build TT LQ4 for 78 Malibu-20131129_215116.jpg
Old 11-30-2013, 01:55 PM
xsivpwr's Avatar
LSA manifold moddification
Old 11-30-2013, 03:27 PM
RedMan*'s Avatar
Wow, very nice set up.
And welcome from another Wa. State member (dry side).
Martin @ Tick Performance is probably your guy to contact for a custom cam.
No room to fit that engine in the 67-68 camaro in the back ground ? J/K
L8R,
Stu
Old 11-30-2013, 04:43 PM
xsivpwr's Avatar
Its a slow expensive project... the list of parts to order never gets small. Plan on getting the cam, bov, wastegates and exhaust by Christmas...$$$
Old 12-02-2013, 08:48 AM
00Wildcat's Avatar
I would highly recommend Holley Efi, the Dominator if you want transmission controls and a LOT of inputs for logging. By the time you add everything you really should have for a turbo engine the Holley is less expensive and you can tune it yourself, even if you have no tuning experience now. You are going to want/need to tune it yourself.
This is also another money, time and space saving option for you
http://www.yellowbullet.com/forum/sh...549765&page=20
Old 12-02-2013, 06:42 PM
stangtrader's Avatar
Nice to see some other people from the seattle area.there are quite a few of us around here
Old 12-02-2013, 09:29 PM
xsivpwr's Avatar
It's wet around here but there are some fast cars in this area. I typically am working on a 10.5 car so it will be a learning curve to get the G-body to hook on the street, if that's even possible.
Old 12-06-2013, 01:17 PM
krwyellowZ28's Avatar
Nice start. I like the simple hot side. I gotta ask why you you added the v-band connections between the manifolds and turbo flange... almost looks like you could've just left those out.
Old 12-06-2013, 04:27 PM
xsivpwr's Avatar
I could have left the v-band out but I wanted to retain some mount flexibility if I ever decided to put this setup in a different car. with all the time it takes to weld manifolds up I also have the ability now to just change the elbow to go to a t4 flange.
Old 12-06-2013, 05:15 PM
smokeshow's Avatar
Send stock48 a pm about the cam. He's the magic man who holds a bunch of records people can't touch. That's your guy for high power stuff
Old 12-06-2013, 10:10 PM
xsivpwr's Avatar
wastegates, bov, gaskets etc. on order. Thanks Lil John for the help and advice...
Old 12-31-2013, 04:43 PM
xsivpwr's Avatar
Build update
Cam (BTR stage 2), WG(40MM), BOV(60MM), injectors(95LB FIC), head studs and gaskets showed up. Thanks Lil John and BTR.
intercooler modification almost done..
[IMG][/IMG]
Old 12-31-2013, 04:46 PM
xsivpwr's Avatar
added pics...
Attached Thumbnails New Build TT LQ4 for 78 Malibu-wg-bov.jpg   New Build TT LQ4 for 78 Malibu-intercooler.jpg   New Build TT LQ4 for 78 Malibu-oil-pan.jpg
Old 12-31-2013, 07:06 PM
allout06's Avatar
cam specs?
Old 12-31-2013, 08:52 PM
xsivpwr's Avatar
Cam specs are 226/231 .605"/.598" 113+4 ...
Old 01-01-2014, 12:03 PM
hbcruiser's Avatar
any oil pan distortion from welding on the bungs?
Quick Reply: New Build TT LQ4 for 78 Malibu
