any difference between a 2004 lq9 and a 2005 lq9?
Old 12-06-2013, 10:11 AM
25thhawk's Avatar
Default any difference between a 2004 lq9 and a 2005 lq9?
looking at 2 different motors with similar mileage. Are there any internal differences? Thanks
Old 12-06-2013, 10:14 AM
smokeshow's Avatar
Could be different rods. Look at the valley cover bolts...10mm means old style rods.
Old 12-06-2013, 10:16 AM
25thhawk's Avatar
out of curiosity what size valley cover bolts means the new style rods
Old 12-06-2013, 10:48 AM
smokeshow's Avatar
13mm.
Old 12-06-2013, 11:06 AM
25thhawk's Avatar
Thanks. I'll check for that. Are you sure that is lq9 parts and not lq4? I've been reading other stuff that says all lq9's have the good rods and lq4's changed in mid 04.
Old 12-06-2013, 11:08 AM
smokeshow's Avatar
I'm not sure. The LQ9 came out quite a while before the LS2, so I wouldn't think its very likely for it to have those rods. They'd have to go back as far as 2002.
Old 12-06-2013, 12:22 PM
nxfirebird's Avatar
there is no difference between the 04 and 05, they probably are from the same run. the LQ9's have the full float rods and flat top pistons, that's why many have got'n away with big power on them.
Old 12-06-2013, 12:40 PM
smokeshow's Avatar
The majority of 2004 engines I've seen have the old rods in them. It was a late model year switch.
Old 12-06-2013, 12:47 PM
Twin turbo c5's Avatar
More than likely both are the same. Valley cover will tell if its a new style.
Quick Reply: any difference between a 2004 lq9 and a 2005 lq9?
