Wastegate/BOV ??
Old 12-06-2013, 10:34 PM
6togo's Avatar
Default Wastegate/BOV ??
What size wastegates and BOV should i use on a 427 with Twin 6767's making around 1kwhp and is one BOV enough or should two be used?
Old 12-07-2013, 09:22 AM
IMPATIENT 1's Avatar
Twin 60mm gates n 50-60mm bov otta work nice
Old 12-07-2013, 10:42 AM
Camaro9969's Avatar
Twin 44s would be fine for gates....Two tiAl bov even a procharger bov would be better than one 50mm
Old 12-07-2013, 10:48 AM
6togo's Avatar
Will the 44's be able to keep the boost down?
Old 12-07-2013, 12:36 PM
toytech93's Avatar
I'd recommend a pair of precision pw46 gates and a single turbosmart raceport bov.
Old 12-07-2013, 12:53 PM
stevieturbo's Avatar
44's would be more than adequate. But the Precision 46's are keenly priced.
That said, Turbosmart do some nice 40mm's now that are pretty cheap and fairly compact.
Depends on how low you want to go with boost.
Old 12-07-2013, 07:14 PM
6togo's Avatar
That was my next question what brand and what are good but decently priced! What about Tials?
Old 12-07-2013, 07:33 PM
You wont go wrong with Tial, Precision, Turbosmart, and no doubt there are other good brands too
Old 12-07-2013, 07:48 PM
6togo's Avatar
So 44-46mm gates and one big or two smaller BOV's will do the job and keep the boost in check.
Old 12-08-2013, 01:14 AM
Camaro9969's Avatar
Depends on budget twin tial 38-44mm or precision 46mm and two TiAL bovs would do the trick just fine just as said depends on how low you want to keep boost. Lower numbers bigger gates
Old 12-08-2013, 07:39 AM
samdogmx's Avatar
I'm doing 2 tial 60mm wg on mine with tial 50 bov Call Reed for the best pricing on tial stuff
Old 12-08-2013, 07:56 AM
MUSTANGBRKR02's Avatar
JGS is a good brand also.
Twin 44's will be plenty.
Old 12-08-2013, 12:47 PM
HexenLord's Avatar
Twin 44s are plenty. Wastegate placement will play a huge part it making the most out of them. With optimal placement, 38s would probably even do the job.
Old 12-08-2013, 01:25 PM
LS1NOVA's Avatar
Ive used Tial 38's on a twin 6765 427 and controlled down to 12psi just fine. Need very good placement though. Also used one 50mm BoV.
Old 12-08-2013, 01:53 PM
transam69230's Avatar
Huronspeed BOVs are good and don't cost a fortune! I know a lot of guys using their BOVs. I have two 46mm precision gates and two 50mm huronspeed BOVs.
Old 12-09-2013, 08:44 AM
Are they Huronspeed BOV's or emusa/ebay renames?
Old 12-09-2013, 10:34 PM
I think they are from China don't think they are relabled. They work and are pretty loud on my car.
Quick Reply: Wastegate/BOV ??
