redundant but what 5.3 is everyone using for turbo builds?
I know there are several variants but I'm planning to build a junkyard 5.3 turbo Camaro. I'm assuming its the LC9 but just want to make sure.
block
Get the cast iron 5.3. F*ck that aluminium b.s. if you want a reliable boosted lsx go with any lq4 lq9 lm7 cast block are WAY better for reliability and piece of mind. Unless you like re-honing the block every year.
Why would you have to re-hone the aluminum blocks every year?
There's nothing wrong with aluminum. The fastest stock LS engine was an aluminum L33 and was running mid-high 8s on stock engine. The aluminum blocks can withstand 1000+HP.
Typically with powerful aluminum blocks you have to sleeve them from my understanding. The #200lb weight savings isn't worth it. Get an iron block it'll hold a better beating and it'll also allow for a bigger bore should you choose to go that route.
If money is no issue at all, sure get an LS3 and go all out, there are just a number of other things you should do to an aluminum block that's not needed on an iron block.
I'm in the process of finding a motor right now and should be getting a LQ4 longblock shortly. Lower compression than the LQ9 so I'll just boost it for now and when it goes boom I'll build it.
$1200-1400 in this neck of the woods.
I would have no trouble running a L33 at 1000hp they have a lot more meat around the bores than a ls1/ls3 does.
Sleeve them? They have pressed in cylinder liners which are thicker than those of the 6 liter engines. No need for sleeves. And as far as bigger bore, there's not much of a reason to consider it unless your walls are in such bad shape that a hone wont be enough.
I have one of the "worst" ones. Iron, gen 3 rods, Great62 heads, but she's making about 750 to the tire on 18psi through a "horsepower robbing" TH400. I really think if the turbo is efficient, the motor doesn't care. The 5.3 displacement is god's gift to the world.
So much misinformation! If you are on a budget and weight is not an issue then go with the 05+ iron block 5.3. If you want to save a little bit of weight (~100 pounds) and want 799 heads (ls6) then go with the L33. The strength issue is a moot point, both blocks are going to handle the same power since they are both 4 bolt heads. You will start pushing coolant before you reach the structural limits of either block.
Any of the LS based (including the L33) aluminum blocks will hold good power. I wouldn't feel comfortable pushing them to 1500hp without block fill and o-ringed block / heads. Though plenty of people on the forum have pushed stock aluminum block (forged internals) ls2, ls3 etc over the 1000hp to the wheels mark without much issue.
