Wastegate solenoids for high Hz
i need to find a wg solenoid that can operate easy at 300+hz
i've seen the GM solenloids handle it
but it doesnt specifically claim high hz tolerance
gm 1997152
thats what im leaning towards.... any input guys?
Sheldon/Robbie if you guys could chime in pls
gm 1997152
I work on BMW's and they use wastegate solenoids around 500hz. You could pull a set off any N54 or N55 engine. BMW calls them EPDW's. Vacuum in, vacuum out and a ev style connector that you can pulse width modulate. Hope this is what your looking for.
its just what we need. Its for a big single turbo conversion N54.
Stock soleniods are a no go. Mac isnt up to it either.
I just need to know a good solenoid to operate in those parameters pls
and if the GM one i posted is worthy
Ask on this forum...but not sure you'll get any different answers.
http://efi101.com/forum/viewforum.ph...2b442295d95aa0
I just need someone to recommend a boost solenoid that operates within those parameters. Forget its a bmw thats not relevant here.
@FourG6397GST
It's a forum where there are people with vast amounts of tuning experience across many platforms. And who don't have closed minds.
I have never heard of any boost control solenoid that operates at that frequency.....but then I've never known any vehicle to have any boost problems that were down to the abilities of a Mac solenoid or similar valve.
Usually problems are down to plumbing. Or user problems with software to control the valve. Not the valve itself.
tell your "guy" that he doesnt know what he is doing and he is doing it teh wrong way...
I dont know all the details of his situation...but I assure you that the problem is not the solenoid...it is the controller or controller settings...
thousand of guys running an AMS-1000 on a Humprhey solenoid that runs around 20Hz controlling 40-50 lbs of boost with no issues...
the key is to have a good pressure source for the solenoid and a good controller.
if he really "needs" a solenoid that operates at 300hz... tell him to use google...you can pull up industrial ones that will do it.
