Eboost2 and New engine break in questions!
Ok guys im close to starting my engine and have a few questions for some of the more experienced guys here..
I'm going to be breaking my new engine in using a base tune from the person I purchased the turbo kit from, very similar engine to mine..
I can either break the engine in on just the smallest wastegate spring (jgs 50mm) and just hookup the bottom port of wastegate to the turbo compressor housing and vent the top port of wastegate to atmosphere.
or since I purchased an Eboost2 should I just install it now like so (diagram attached) and just set the lowest boost setting I can...
I still need to play with the eboost2 to learn how to set it and whatnot, and I won't be going over 2k RPM's while I break it in but wanted to know if its smart to hookup the eboost now vs later after break in..
pros or cons?
thanks for the help
pros or cons?
thanks for the help
I just broke in my turbo motor with the 7# waste gate spring. My car wont build boost until after 3000 rpm, so it didn't really matter how I had it hooked up. While breaking in you need to vary the RPM, keeping it under 2k will not allow it to break in properly. Anther option is to not hook pressure to the BOV, this will allow boost to leak out before the intake.
why do you want to baby it? why don't you just get it running, check temps, pressures etc on the dyno and start dialing in the boost you wanna run. if everything looks happy change the oil and hammer it
But have heard to drive it hard right outta the gate is better for ring seal..
Then wait. Just do some heat cycles and preliminary driving to check for leaks or mishaps of any sort and then change oil. Hook up the boost2 and then wait for tune day to break it in.
Now if the base tune is close enough then slowly work your rpms and loads up til you get into boost. Use lowest setting spring you got. Do a few pulls like this to break it in abit then change oil and go get a tune
