Best heads/intake/tb for a forged 370 build??
Old 12-18-2013, 10:18 AM
RCSBTURBO4WD's Avatar
Default Best heads/intake/tb for a forged 370 build??
Hi, I need some help deciding this..
What heads should I get for my 370 boost build??
I have a TBSS complete intake/tb/x-link setup that I bought for my engine on my signature but now I dont know if I should put it on my new engine or if there is better ways to go.. I have my turbo sitting in my garage I just want to build my 370 the right way.. Should I pick a set of 243's and put the TBSS intake setup? or which heads should I go with?
Thanks in advance!!
Old 12-18-2013, 10:22 AM
1badeagle's Avatar
317/ls6 is what I'm running and it has taken me to 800whp easy
Old 12-18-2013, 10:40 AM
SPRAYED 01's Avatar
What turbo and that are your goals? Ive got old school 241 heads ported with ls6 intake/tb and did 900whp on 20psi
Old 12-18-2013, 01:23 PM
Precision 76/68 .98a/r and want to do over 700rwhp..
Do you guys think thats achievable with my current 5.3?? Should I give it a try or should I leave it alone and swap in the 370?
Old 12-18-2013, 01:29 PM
10secZ28's Avatar
700 is easily achievable with a good turbo, i made 850 rwhp on 22 psi with stock 862 heads, I made 730 on 17 psi, and mine is a 5.3.
Old 12-18-2013, 01:45 PM
DEFYANT's Avatar
I would do some ported 243s or 317s and a LS6 intake with a ported TB.
Old 12-18-2013, 02:01 PM
Holy.. Pump gas??? I bought a devilsown meth injection to put in my setup too..
Old 12-18-2013, 09:36 PM
dj94gt's Avatar
On Jessie's Real street car, he has an old school set of 215 trick flows. It's still on the hyd. roller valvetrain, billet wheel 76mm, and makes over 1100HP @ 20psi
Old 12-18-2013, 10:04 PM
HexenLord's Avatar
L92 heads if you go with the 370. They flow ridiculous right out of the box.
Btw, the turbine on that turbo is a little small for much over 700whp. Is it a billet wheel?
Old 12-18-2013, 10:58 PM
coolmanvette75's Avatar
I'll be running TEA CNC'd LSA heads and a ported LS3 intake on my turbo 370 setup...
Old 12-19-2013, 12:51 AM
oscs's Avatar
L92/LS3 intake
Old 12-19-2013, 01:33 AM
Yes, actually Rick put the kit together for the 5.3 on my sig, he said that turbo(76/68) will be a very fun-fast spooling setup, and capable of being close to 700, I just dont know if my 5.3 can stay together with that much hp..
I guess i would need to be around 17psi right??
Old 12-19-2013, 04:45 AM
2002TTTA's Avatar
What size motor and what turbo?
Old 12-19-2013, 08:18 AM
1CAMWNDR's Avatar
If you are building a 370 use L92 or LS3 heads with good valves and valve job, a Victor Jr intake manifold, and a low profile (Accufab or Scorpion) 4BBL throttle body.
Old 12-19-2013, 08:42 AM
dj94gt's Avatar
TFS 215cc heads, 235cc exhaust port, S400-76 billet wheel. 21psi @ 7400 rpm. Hyd. roller.
Old 12-19-2013, 06:29 PM
slowbu's Avatar
X2 good setup
Old 12-19-2013, 07:07 PM
SPRAYED 01's Avatar
Personally id save the money on heads and put it towards a turbo with a larger turbine
Old 12-19-2013, 11:37 PM
qqwqeqwrqwqtq's Avatar
Agreed.
Old 12-20-2013, 04:32 AM
samdogmx's Avatar
how much money do you want to spend? My forged 370 ran 9.0 with untouched 241 heads & proflo intake.
Old 09-17-2014, 08:40 AM
Old post, just read it and wanted to let you know the way I went (in my signature), still working on it, waiting on my FLT tranny for now, everything else sitting in my garage..
Quick Reply: Best heads/intake/tb for a forged 370 build??
