What type of heat shield material is this?
Old 12-26-2013, 10:27 PM
Ping King's Avatar
Default What type of heat shield material is this?
What type of heat shielding is this? I see that the material can either be inconel or aluminum. I would like to purchase it in sheets to be bend, shaped, etc.
I know APS had them on their turbo kits. It seems like this material is big in the UK and AUS.
I also know that it can be referred to as "Double Wall Aluminum" or "Embossed Aluminum"
Any help?
Old 12-26-2013, 10:56 PM
HexenLord's Avatar
Tons of manufacturers out there make heat shielding kits.
http://www.summitracing.com/search/p...at-shield-kits
http://www.jegs.com/p/JEGS-Performan...82211/10002/-1
http://www.jegs.com/p/DEI/DEI-Heat-S...98875/10002/-1
Use these two links, there are tons of different products.
http://www.jegs.com/c/Exhaust-Header...10261/10002/-1
http://www.summitracing.com/search/d...eat-protection
Old 12-26-2013, 11:05 PM
Ping King's Avatar
The only thing i can see that may be close is the DEI floor and tunnel.. Link below:
http://www.summitracing.com/parts/dei-050503/overview/
The material i am looking for is hard. Its what OEM's use for heat shielding as well. Often pressed into shape.
Old 12-28-2013, 10:31 AM
LS1-IROC's Avatar
I don't think that DEI stuff is rigid like what you are looking for (due to it being adhesive backed). I have been looking around for the same type of stuff as you are describing. Update this if you find something that works.
Old 12-28-2013, 12:27 PM
Exidous's Avatar
http://www.turbosource.com/Heat-Management-s/1842.htm
Note the label on the first image. :-)
Old 12-28-2013, 12:33 PM
stevieturbo's Avatar
Christ...look at the price !!
Old 12-28-2013, 12:52 PM
Exidous's Avatar
Apparently it's all inconel. /shrug
Old 12-28-2013, 01:05 PM
AutomagicLS1's Avatar
almost $700 for a turbo blanket
Old 12-28-2013, 01:18 PM
Exidous's Avatar
Damned people from Minnesota charging crazy prices....
Old 12-28-2013, 01:19 PM
Exidous's Avatar
Hrm.....Turbo or turbo blanket...... 2 of you On3
Old 12-28-2013, 01:44 PM
Ping King's Avatar
I know haha...that why im trying to find the aluminum material to do it myself. I have access to a bending brake and sheet metal tools.
I have 600 bucks into my entire hotside, i dont want to spend another 600 on just a turbo blanket.
Old 12-28-2013, 02:35 PM
RonSSNova's Avatar
Nice stuff for sure. Need to find who makes the sheet stock. Still going to be spendy. That company seems to build for high end racing applications.
Ron
Old 12-28-2013, 02:47 PM
Exidous's Avatar
They are SUPER spendy because they are apparently made from Inconel. The same stuff REALLLLLY high end F1 type race car manifolds are made out of. They can take any hear you throw at them.
Quick Reply: What type of heat shield material is this?
