SOM LAG Project: 394ci, 25.3, Twin PT7675 Gen 2's, PG, E85, 7-second Street Car
#342
I had to notch the back of the shifter opening a little bit when running the 4L80 in order to reach low. I am not sure if it is needed or not with the Glide. I would guess the gate pattern is shortened with only the two gears versus four.
I will be at the shop tonight for a little while and will snap a few photos.
#343
Took a couple photos of my shifter:
Overall photo. The silver trigger hits the plastic up front. It makes it a little difficult to get in park. This could be easily fixed by raising the shifter a touch.
Side view to show how close it gets to the radio / HVAC bezel.
Overhead shot of what was cut (for the 4L80):
Shifter position in Low with the Powerglide. I don't think the console would necessarily need to get cut with proper shifter placement (I don't have that kind of patience).
#344
Awesome. You provide alot of detail in you post. I appreciate that. I am starting my build now. Starting with the rear end and suspension. My cousin is trying to figure out the engine and trans combo. I would eventually like twin turbo. Maybe a good 3 year project but it will be fun.
#346
I don't care for the guys that hide large details and keep stuff hidden. It doesn't show what is really going on with the cars, builds, as well as help for troubleshooting / builds for others. There are too many Internet heroes out there that keep things hidden.
Needless to say, I think grudge racing is the dumbest thing around.
They offer a sale about once a year. I had ran across it on Facebook. I called a few minutes before they opened to see what they had available. I was planning to only order fronts, but decided to change all 4 corners after calling. Figure these should last a while.
#347
Small photo updates.
Received my front coilover springs the other day and the brackets for the front and rear to mount these with the clevis style mounts.
Also received word that my Siemens 220's were shipped today and should arrive on Tuesday. Will be switching from the Holley 160's to the Siemens 220's.
Couple more months until Spring. Tentatively planning for NHRA Chassis Certification on April 9th and hopefully the first track outing on April 29th.
#351
Wheels are Weld RT-S, black, 15x10 (7.5” BS), 15x4 (1.5” BS).
I am not 100% positive, but I remember being the medium pad height (which I believe were mostly built for 4th gen F-body). I think I have very minor shaving of the factory calipers to get them to fit. It was something strange like one side fit and the other side needed very slight touching up.
Rear brakes are Strange pro drag brakes. I believe the part number is B1718WC.
#353
I would also recommend narrowing the rear if you don't plan to run factory wheels. There is weight to be lost there. You also could end up running a double beadlocked wheel if would like. The look of the wheels is also much better with the dish.
I would highly recommend the Strange S-trac differential as well. If it was available when I bought mine, I would have gone with it. It is a big hit to the pocketbook, but worth every penny. A couple buddies bought it and absolutely love it.
#354
I looked at all the midwest chassis stuff. I Like it. I am building the whole car little by little. I am trying to over build the rear, suspension and brakes right now. To grow into it. I wanted to narrow the rear 3 inches a side and do a 5.5 bs on the weld wheels. It is funny when I bought my car 2 months ago I stopped at my cousins shop on my way to Illinois and he asked what i wanted to do to my car and I sat him down and pulled up this thread and told him to keep reading. I have learned alot from this thread and I keep rereading it. Hope you can make Pontiac Nationals at Norwalk this year. Would love to see your car in person. I will probly have a bunch more questions in the future. Thanks again
#355
Keep firing away on the questions. That is what I have the thread for. The interaction is good.
Will have to see what summer brings.
#357
I was very impressed with the Viking shocks. The only reason I went away from them is looking for some different valving and help with the launches. I was considering upgrading the front Warriors to Crusaders, but the price I got on the Menscers, I couldn't look back. Very solid pieces for the price. And the best part, they are manufactured about 70 miles from my house.
#358
Another small piece to the puzzle for this year. Received my Siemens 220 low impedance injectors. Going to switch from the Holley 160's to give me a little more room.
Probably looking at starting to install some of these components within the next two weeks. Not sure if I want to take the cover off the car or not!!
#359
Starting to have a little bit of spring fever. Figured it was time to get the car ready for Spring. Pulled out the seat belts and going to send the belts and window net in for recertification.
Swapped the Holley 160's for the new Siemens 220lb injectors. Only keyed the car on tonight to check for fuel leaks. Need to update the tune with the new injector data and fire the car. Will probably happen tomorrow night.
Also swapped the Viking coilovers for the new Menscer Motorsports coilovers. Swapped the factory mounts the tops of both the front and back for clevis mounts. Didn't have my spanner wrenches to adjust ride height. Will be working on that tomorrow night as well. Should have photos at that time of the new setup.
Put together a for sale ad for both the Vikings and the injectors (see for sale section). Hopefully more to come soon. Can't wait for Spring.
