Neez's Boosted build
Hey guys, Havent really posted much on this forum but figured id get some reviews and input on my latest build.
The car started as a NA build a couple years ago, but have decided to go to the forced induction dark side.
the car is a 01' Corvette Z06.
Current mods:
Stock LS6 bottom end
PRC 225cc cnc ported heads
MS4 cam
Fast 92/92
LG longtubes
B&B bullets
RPM Stage 5 t56
Monster stage 5 single disc clutch
DSS Output shafts
42Lb green top injectors
Scorpion roller rockers
Stock 3.42 gears
NOW for the upgrade
Hinson Motorsports Hot/Cold Single turbo setup
Masterpower T70 with .96AR
custom grind 230/230 .615/.615 on a 115 LSA
FAST fuel rail
Dual 255walbro fuelpumps with return style fuel system
60lb/hr injectors
Racestar 94 Superstar darkstar bigs/littles
I will be keeping the stock bottom end for now, unless something lets go. I will still be runnning the 225cc prc heads with 62cc chambers. It will be a little higher than normal compression at 11:1ish, but Planning to only run 6-10lbs boost. Im a little unsure of the turbo size though, I believe it flows a max of 86lbs.
If any of the guru's have suggestions, or tips for me im more than happy to hear em! Hoping to make somewhere around 650whp.
Current mods:
MS4 cam
Fast 92/92
LG longtubes
B&B bullets
RPM Stage 5 t56
DSS Output shafts
Stock 3.42 gears
NOW for the upgrade
FAST fuel rail
60lb/hr injectors
