turbo manifold
Old 01-04-2014, 03:49 AM
jiggler's Avatar
Default turbo manifold
Sorry if this has already been talked about but I searched and didn’t see anything on it. My question is there a distinct benefit on running a custom set of steel manifold(s) vs the reversed truck manifolds. Reason I ask is because I was looking at a set of customs ones but they’re going to run me $1600-2200 vs having the truck ones cut and welded (sure I can get it done for $400). Or is it just a cosmetic thing that looks nice.
Old 01-04-2014, 07:28 AM
Camaro9969's Avatar
What kind of power are you looking for?
Old 01-04-2014, 07:31 AM
mrstepheneades's Avatar
Ive seen truck manifolds go beyond 1200rwhp.
Old 01-04-2014, 07:40 AM
stevieturbo's Avatar
Tubular manifolds can see benefits, but a lot will depend on your goals.
Plus most tubular manifolds will restrict plug access. Maybe a small point, but I'd hate to have to change plugs on some of them !! That would be enough to sway me from some designs.
Here's a thread asking about some shorties.
http://www.camaro5.com/forums/showthread.php?t=333810
Old 01-04-2014, 08:22 PM
jiggler's Avatar
plan only to take it to 1000whp max... but I dont know if that that itch will come biting and im going to need/want more.
Old 01-04-2014, 08:38 PM
x275radial's Avatar
just use truck manifolds or use the hooker smooth looking manifolds like I did. you will be fine. I seen a Camaro make 1279 whp with manifolds. if I can find my camera ill post the vid.
Old 01-04-2014, 10:40 PM
jiggler's Avatar
okay thanks for the input fellas
Old 01-05-2014, 09:33 AM
CornFedLS's Avatar
Yeah you should be fine with truck manifolds
Old 01-06-2014, 09:07 PM
bmr408's Avatar
They will make that hp no problems
Old 01-07-2014, 10:50 AM
necrocannibal's Avatar
I had tubular manifolds and and kept burning plug boots. It was a PITA to deal with as there wasn't any room. I switched to truck manifolds and.
Quick Reply: turbo manifold
