New turbo set up help cross over pipe size
Old 01-06-2014, 11:54 AM
Hulkls1's Avatar
Default New turbo set up help cross over pipe size
I'm changing my set
5.3 stock 706 heads
Z06 cam
Gt45 ebay turbo
4l80e tranny
373 gears
3680# car
My new set up
L33 5.3
Custom cam
S475 96mm 1.34 ar
4l80e
3600 stall 373 gears
My question is my hot side is 2.75 from manifold to the turbo if I make a new hot side with 2" pipe would it help spool the s475 better I drag race my car a lot and street drive it to it has a/c and all I race 1/8 mile car runs 6.38 et now going to try to put it in the 5s
Old 01-06-2014, 12:02 PM
Twin turbo c5's Avatar
Yes it should help spool time . I'm not sure how much it depends on the setup. I've always used 2 1/4 and mostly 2 1/2 on my 76mm and s480 I'm sure 2 inch will help on that 5.3.
Old 01-06-2014, 12:23 PM
Hulkls1's Avatar
I'm trying to be the first car around my town that's put a 5.: street car in the 5s lol my gt45 is making power but I want to set up I know my hot side is big now I thought if I went 2" I know it would spool better
Old 01-06-2014, 08:00 PM
chevellepowered's Avatar
i run 2" pipes to my turbo , short and simple , truck manifolds .... comp 7879 .. i like it , and plan on making my own manifolds in the future 1 7/8 primaries into 2" pipe all the way to turbo .. .
Old 01-06-2014, 08:36 PM
bmr408's Avatar
I would do 2 1/2
Old 01-06-2014, 11:20 PM
LILHEMI's Avatar
I did 2.5" on my 5.3. Wish i would have gone 2.25" in hindsight.
Old 01-07-2014, 01:29 PM
Forcefed86's Avatar
https://ls1tech.com/forums/forced-in...over-pipe.html
After reading all of that 2" would be my pick for under 1000hp.
Old 01-07-2014, 02:46 PM
Hulkls1's Avatar
Now my set up has changed I have a 6.2 ls3 I'm going to put in my car with a s480 96mm 1.32 ar t6 I'm going to use a 2" cross over pipe gaol is only 800-850 hp rear wheel hp just be a big jump in hp over the 5.3 lol
Old 01-08-2014, 08:31 AM
bad6as's Avatar
2 or 2.25
Old 01-08-2014, 10:16 AM
THADD's Avatar
On my 347 with a 76mm with a 1.58 a/r we are trying 2.25 to see how well it works. We also kept equal length from manifold to turbo from each side.
Quick Reply: New turbo set up help cross over pipe size
