Twin Turbo LSX Datsun 280Z
a long time ago I built a 468 BB chevy 240 z used the ls6 flat intake with some open chamber square port heads
manifold was a bit restrictive but it allowed it all to tuck under a stock hood
quite the sleeper thing wouldn't hook at all and it twisted and contorted but it was extremely fast on top end and a hell of a ride always
now for sure I'd build a turbo ls motor
I'm thinking of a 4.8 iron block build to try out some nice gt35s
a long time ago I built a 468 BB chevy 240 z used the ls6 flat intake with some open chamber square port heads manifold was a bit restrictive but it allowed it all to tuck under a stock hood quite the sleeper thing wouldn't hook at all and it twisted and contorted but it was extremely fast on top end and a hell of a ride always now for sure I'd build a turbo ls motor I'm thinking of a 4.8 iron block build to try out some nice gt35s
Boost is the only way to go in a setup like this. In my particular case a little lag probably wouldn't be a bad thing. With two turbos though I doubt that will happen.
That is just crazy.. I could imagine your lack of traction with that much power down low. A lot of people argued with me about the ease of a supercharger vs. Turbo but It was a no brainier to try and get the power higher in the RPM range (turbo) due to the weight and tire size constriction..
Is that 4 lug up front? Are you using stock ball joints and control arm? Or did you up grade to something different. Looking good.
Kerry
Kerry
Getting some little **** done. I'm getting some binding in the steering so I might have to tear it back a part.. Oh well.
Attachment 434805
Attachment 434806
Attachment 434805
Attachment 434806
#35
Would probably look alright, I'm just a fan of the sleek look
I kinda like the factory look. You see setups that you would swear came in the car from oem. I like that look.
Car is coming out great. I been debating changing mine from black to white. I will probably end up Mat Black
#36
Thanks for the replies. I have a friend that is going to do them basically for free so I figure why not. I'm still not sure what color to do.. I really think white would be badass but I'm afraid I'm going to have to much PC under the hood after it's all said and done
#37
Well my goal was to get the turbos mounted (mirrored) but these manifolds took a lot longer than I imagined and the hot side piping is going to be a nightmare. I'm going to end up with some pretty nasty angles in order to get the turbos the way I want them.. Oh well.
I had to move the lower radiator support a full 3" to make room for the filters and turbo. By next weekend I should have them mounted or at least close to it.
Also got the cross bars back from powder coat
#38
Nice work. Can't wait to see the final product
Attachment 435801
Attachment 435802
Attachment 435803
Attachment 435804
Attachment 435805
Attachment 435801
Attachment 435802
Attachment 435803
Attachment 435804
Attachment 435805
