Twin Turbo LSX Datsun 280Z
Old 04-20-2015, 09:11 PM
  #781
mistafosta's Avatar
Originally Posted by oscs
Also what about running a really good converter that will lock up in 3rd? Would that not help the cause quite a bit?
Lockup will mean zero slip, yeah that will help. But again it won't get you past the ratios. Only eliminate the slip.
Old 04-20-2015, 09:15 PM
  #782
s57_s2k's Avatar
28" tire calculations sound about right?
how come the calculation for 3.54 gear equal the one for 3.36 gear ?
  #783
oscs's Avatar
Originally Posted by mistafosta
For example a 28" tire and 3.54 rear end with 1:1 ratio is 164 mph at 7000rpm
Yup, I was inputting the data wrong.
Old 04-20-2015, 09:17 PM
  #784
mistafosta's Avatar
Man what is up with this calculator then? Where are you getting your numbers?
http://www.catherineandken.co.uk/sti/tyres.html is usually what I use. Just plug in 1:1 for one of the ratios and 275/60/15 for tire size. It's not as comprehensive but it seems to be way more accurate lol.
Old 04-20-2015, 09:20 PM
  #785
oscs's Avatar
165 isnt going to cut it for me. So GM doesn't make a 4spd auto that can hold this kind of power?
Old 04-20-2015, 09:23 PM
  #786
mistafosta's Avatar
I don't think anyone makes an overdrive auto that will hold 1khp in OD
Old 04-20-2015, 09:25 PM
  #787
oscs's Avatar
What I need is a true 4spd auto with a "5th gear OD"
Old 04-20-2015, 09:43 PM
  #788
RonA's Avatar
That 47rh is looking better and better. :-)
Old 04-20-2015, 09:46 PM
  #789
Mongoose350's Avatar
Give NTX Coverter a call. I spoke with them once about an 80e. There super cool and will explain everything, and will build you somthing for whatever you need. Price might be more than you want to spend, but they will at least help you figure out if what you want is possible.
Old 04-20-2015, 10:22 PM
  #790
rotary1307cc's Avatar
8.8/9" IRS swap is the most logical step here. You get strength with a bunch of gear choices. For not that much money
Better if to cut the losses now with the r200
Old 04-21-2015, 01:28 AM
  #791
stevieturbo's Avatar
What most auto guys do and what Z says, you need a taller diff.
Most fast auto guys end up in the 2.x range for a final drive to give them some top end ability
AFAIK you can get an 8.8 down to around 3.08, although the gears dont seem that common. Viper rear would be 3.08 too.
Old 04-21-2015, 07:12 AM
  #792
oscs's Avatar
I ran across a thread last night where a guy married a 2.94 Nissan Armada R&P set with a R230 300ZXTT diff. Those diffs are massive @ 9.05". At this point there is nothing else I can do minus tearing everything out and either back halving the car or trying to engineer an 8.8 setup.. Looks like I'm going Armada/300ZX diff shopping today.
Old 04-21-2015, 10:51 AM
  #793
8.8 gears are everywhere. Easy as cake to get 3.08 or 2.73. I have a set of both just sitting here
Old 04-21-2015, 11:22 AM
  #794
Forcefed86's Avatar
You have to put it all into perspective. You are racing 300k+ super cars. 10k worth of trans. parts is a drop in the bucket to those guys. You can’t expect budget parts to hold up to 1300whp reliably.
I’ve seen used aftermarket case glides for $1500 or less quite a few times. Same with GV units. Ebay usually has a few. If you’re on a budget, you need to look to used stuff and learn how to go through it/rebuild it. The glide is by far the easiest auto trans to work on that will hold up at 1300whp. If you don’t’ want to redo the rear, the glide/GV unit is the cheapest option that can handle 2k worth of power. Also if your doing roll racing, you may get away with a stock case for a few years. I paid $700 for my stock case glide with all the goodies. 3 years of T-brake launches... so far so good.
The GV unit on a glide is no longer than a standard TH400… A .78 final gear would give you some healthy top end, even with the 3.54's.
https://gearsplitter.wordpress.com/2...ur-powerglide/
Old 04-21-2015, 11:43 AM
  #795
oscs's Avatar
Switching to an 8.8 is not anywhere as easy as it sounds, Do able but not easy. Not to mention the cost and i would have to try and sell all this stuff. It would be a massive undertaking at the moment.
Old 04-21-2015, 11:46 AM
  #796
oscs's Avatar
I want this more and more.. If i could find a used GV for $1500 or so i would do it in a heart beat. I am defiently capable of building up a glide i just need to do some research and look around for used ****. Where are you finding these deals in used stuff?
Also is the GV unit on the back of a "shorty" glide? that looks like it would fit the tunnel nicely, If not i would make it fit.
Old 04-21-2015, 11:53 AM
  #797
Once it's done, it's done. Look long term if you're really that worried about the existing one breaking.
or just take a chance and keep running the existing setup
Old 04-21-2015, 12:03 PM
  #798
oscs's Avatar
So the big lure to the GV unit is that you can actually use the OD at WOT where the 4L80E OD is basically useless for anything other than cruising.
Old 04-21-2015, 12:07 PM
  #799
Why not speak to someone at RPM etc ? There are bound to be some guys with good power with the 4l80 ?
Old 04-21-2015, 12:21 PM
  #800
oscs's Avatar
Ive talked to FTI, and jake. They both think the same thing, Glide for track 4L80 for a mix or "roll racing." Regardless of glide vs 80E i will always be at the mercy of my rear gear.
Using a 4L80E with my 3:54 gear will net me the same speeds as the glide. Not being able to go WOT in OD with 80E pushes me away. besides being able to "cruise" whats the point of it?
Now a glide with an OD i can actually hammer on is the answer for me.. I keep my rear end intact, I get a great low gear out of the hole, I minimize shifts ans I still get to use all that power up top and i can cruise the car.. WINNING!
Quick Reply: Twin Turbo LSX Datsun 280Z
