My 2000 Camaro Z28 turbo build 5.3 FI Billet S480
Old 01-12-2014, 01:02 PM
caMnaro's Avatar
Default My 2000 Camaro Z28 turbo build 5.3 FI Billet S480
I bought the car when i was in high school and it was a stock with a 6 speed. It started with heads and cam and wanted more. Put a dry kit on it and changed over to a stalled auto. Few years later the motor went and i decided to build a turbo car. I have been collecting parts for a while and finally am starting the build process. Need to get a lot more pictures.
Car:
BMR turbo k-member
BMR Upper and Lower control arms
Manual rack and pinion
SJM abs delete kit
Tick Performance Battery relocate w/ BMR mount
A/C delete
Qa1 shocks front and rear
Spoon adj. torque arm
Spoon dbl adj. PHB
Center line Telstars
VFN Sunnoco hood
SS Wing
Billet front grill
Weld in sub frame connectors
Cooling:
Griffin stand up radiator
Two Derale 16925 pusher fans
still have factory WP thinking of going to meziere electric
Kurt Urban LS Water Vapor System
Motor:
Stock 2006 LM7 with 80k mi
Brian tooley .660" Platinum Spring Kit with Titanium Retainers
ISKY 218 cam
melling High volume oil pump
melling stock replacement lifters
chromoly pushrods
ls2 chain
Head studs
Ls9 gaskets
Ls6 intake and TB
Trans and Rear end:
Th-400 RMVB with brake, built but don't know whats inside, has been 9.teens already
3200 torque converter from a old setup will be using for now
B&M Super cooler
Moser 12 bolt 33 spline axles with spool, still has 4.11 gear need to change
Turbo kit: Only thing needed to be built still
Forced Inductions S480 Billet HO turbo 96mm turbine, Thanks again JOSE
Two JGS 40MM Wastegates
JGS 50mm blow off valve
Front mount intercooler 31x12x4
Fuel System:
Stock tank
Two x Walbro F90000267- Fuel Pump 430LPH, E85
one pump on a hobbs switch
-10 PTFE lined feed
Stock feed as return
Holley fuel rails
Still need injectors and a regulator was going to go ID1000 but seem like the reviews on E85 are not that good. Maybe the new ID1300 but at 1800.00 for a set
What is the part number for the siemens deka 127??? i have read about. They seem to do well on E85 and should have this motor covered as far as flow.
Will add more pictures later when i pull it out of the garage and clean the dust layer off
I have all the parts except for the injectors, Fuel pressure regulator, and the turbo kit needs to be built. I got the motor home this weekend and started assembly. Hopefully i can get the car drivetrain in within the next few weeks so i can drop it off some were depending on work . I Have talked to Steve @ Legend Racing about doing the fabrication a while ago, depending on his schedule probably will go there. Clean work as far as the builds i have seen and looks to have a good handle on ls cars.
Thanks for reading Mike
Old 01-12-2014, 01:20 PM
Burken01's Avatar
Nice looking build! Lm7 engines are the shiz...
Goodluck
Old 01-12-2014, 02:11 PM
slowlsx's Avatar
Http://billetatomizerinjectors.com/
Old 01-16-2014, 11:37 AM
caMnaro's Avatar
Do they have a high impedance inj did not see any on their website? Anyone prefer AEM over the versafueler converter?
Old 01-16-2014, 11:44 AM
caMnaro's Avatar
Couple more part pictures
Walbro 430 L/hr e85 pump x2
Racetronix Dual circuit fuel pump harness.
Old 04-04-2014, 12:13 AM
caMnaro's Avatar
Past week i have been working on a lot to finish the car. I installed an abs delete kit and some new rear suspension parts. Got the trunion done to the rockers and installed the BTR valve springs on the heads.Got the motor built today and will be put in on Saturday. I did change from the LS6 cam to an Isky cam from stock48. Will get pictures of the car this weekend when i put the motor and trans in. Also got in my AMS1000.
Old 04-04-2014, 08:24 AM
Ryans99ls1's Avatar
You are throwing some really nice parts in this car! Glad to see you didnt stick with the ls6 cam. Should really rip. good luck
Old 04-19-2014, 11:48 PM
caMnaro's Avatar
I have installed the SJM abs delete kit along with new front brake lines on the k-member. Finished the brake lines and also removed the old fuel lines. Also finished mounting the intercooler and radiator. Got the motor and trans bolted together and in the car today. Hooked up the water pump and alternator. I dropped off the deposit for the fabricator last week, and the car leaves in the next few days. It will be a few weeks but the complete kit will be done.
Old 04-19-2014, 11:50 PM
caMnaro's Avatar
Yea i think it was the right choice in changing the cam. Thanks, hopefully it all is worth it in the end
Old 04-20-2014, 01:19 AM
Silver6.0's Avatar
im doing a similar build. what rings are you using? and what gap are you going to run?
Old 04-20-2014, 08:02 AM
Blackpanther99's Avatar
In for results! What are your goals??
Old 04-20-2014, 10:12 AM
caMnaro's Avatar
Stock rings with stock gap. Some people say to open them up and others say leave them. I will see what happens
Old 04-20-2014, 10:15 AM
caMnaro's Avatar
I would like to be able to drive to and from the track and run faster then it ran before the turbo build. so 10.50s but would like to go 9s in the 1/4.
Old 05-06-2014, 03:43 PM
caMnaro's Avatar
Car was dropped off at the fabricator last week. Should have some turbo kit pictures soon . Also the water pump and radiator and going to be converted to -16 an fittings and lines to clean up the engine bay and should be easier to route.
Old 05-06-2014, 08:50 PM
baggins's Avatar
Mind if I ask what the bellows ran ya?
Old 05-07-2014, 12:34 PM
caMnaro's Avatar
I don't know if i am allowed to post non-sponsor pricing, so just pm me or call rudy @ Reid Washbon Racing Exhausts 949.548.9783
Old 05-07-2014, 12:56 PM
smokeshow's Avatar
This car with the parts you've got has 8s at 160+ in it. Gonna be a nasty bitch
Old 05-10-2014, 09:34 PM
caMnaro's Avatar
Thanks that would be awesome to run that
Old 05-10-2014, 09:36 PM
caMnaro's Avatar
The fabricator got some done on the kit. Inter cooler is mounted and radiator brackets are made and in. Hotside and start of downpipe also.
Old 05-10-2014, 10:40 PM
fastsspr's Avatar
It looks like it going to be a very clean job!
Quick Reply: My 2000 Camaro Z28 turbo build 5.3 FI Billet S480
