Anybody using holley dominator and methanol
Old 01-13-2014, 07:21 PM
Daniel Nicastri's Avatar
Default Anybody using holley dominator and methanol
Is anybody using the holley dominator and methanol
Old 01-13-2014, 10:10 PM
71 chevy's Avatar
Yes, what do you need
Old 01-13-2014, 10:14 PM
Is it any good for methanol??? I've got it on e85 now but I'm not what to do when I go to meth, do I just set the target a/f in and put it in learn mode ??
Old 01-14-2014, 08:44 AM
71 chevy's Avatar
you'll multiply all your fuel tables by a factor to get it close for methanol and then tune from there.
when you click on conversion in the base fuel table, what ve numbers are you seeing for e85
Old 01-14-2014, 11:36 AM
stevieturbo's Avatar
The ecu doesnt care what fuel you are using.
"Learn" can only take you so far. Obviously you need a sensible base map and setup first.
Although make sure they offer a wideband compatible with methanol.
Old 01-14-2014, 12:33 PM
JAX04's Avatar
There NTK Sensor is fine and good to go... BMF Comes to mind on his setup, dominator, single, methanol, and there are a few others on bullet. Get there good NTK sensor.
Old 01-14-2014, 03:51 PM
ButchB's Avatar
I'm gonna run the holley also and plan on using atomizer 225 injectors. If you're changing to larger size injectors and higher than stock fuel pressure, say I go with a 50psi base pressure, how is this gonna affect setting the fuel tables up to get it up and going. I know meth is about double but it seems like it'd be really rich even at stock fuel table settings??
Old 01-14-2014, 05:18 PM
I've got the ntk sensor already. Does any body hav a base file for meth I could use to start from
Old 01-14-2014, 06:39 PM
71 chevy's Avatar
you tell the holley what fuel pressure you are running and what size the injectors are and it controls the injectors so the lb/hr fuel flow is realized.
Old 01-15-2014, 05:36 AM
ButchB's Avatar
Cool, thanks. It seems like you could just take the base tune and double it to get a good base tune for cranking then, right?
Old 01-15-2014, 10:28 AM
BMF_Racing's Avatar
Question
if you have a engine running on gas, increasing the fuel table 100% will get you close enough and it will run on Methanol. Anyone know what the ratio is from Gas to E85? or E85 to Methanol?
If his is running on E85 now, its really just adjusting per this ratio (and fuel type in the main table along with new AFR tagets for Meth) and it should be close enough for learning to start doing its work.
Old 01-15-2014, 03:51 PM
I'm using them injectors as well Alan from billet atomizer told me if I turn base fuel pressure up to 70-80 psi I can make 1300-1400 flywheel which should be enought to make my goals 1000rwhp..
Old 01-15-2014, 03:53 PM
What's methonal like to cruze around with on the street does it use a lot of fuel will it milk the oil up
Old 01-16-2014, 07:45 AM
BMF_Racing's Avatar
Post
Mech injection has given methanol the bad rep of milky oil. Overly rich conditions cause the milky oil. With EFI and a good tune this should not be a big issue. Will you change your oil more often than gas, yes but it will not be terrible with a good tune.
As far as usage, it will use twice the fuel as gas or 70% more fuel than E85 at WOT, slightly less % at a cruise.
Quick Reply: Anybody using holley dominator and methanol
