Tick Performance LT1 turbo build 907rwhp/860rwtq 19psi
Old 06-05-2014, 08:49 AM
  #61
SwampWS6's Avatar
Wow simply amazing! I have been following for a while gives me hope with my build. Great job guys!!!!
Old 06-05-2014, 09:54 AM
  #62
Sales@Tick's Avatar
Originally Posted by Blackbirdws6
Excellent job. What piston rings are you running?
Total Seal rings.
Originally Posted by BLK95-Z
Awesome numbers! You guys did a great job
Ive asked Tony about his block before and he said he did a half fill, 4 bolt main splay and plugged the deck. Never hurt one
I wish we could fill this one and plug the deck, but that's race car stuff there. We could probably get away with a half fill if we ran an oil cooler and the cooling system was super beefed up.
Plugging the deck would require running water externally to the heads as well.
About the only thing we could do to safely make more power and do it reliably is swap everything over to Gen 1 SBC. Run a Dart SBC block, Dart SBC heads, Dart SBC intake and then fit the 24x kit to that engine.
IMO anyone with a LT1 set-up that wants to make huge power would do just that.
We're being cautious with this engine since this is uncharted territory for us with a LT1. The tune-up is super safe going off plug readings.
We're also really pushing the flow rating of the Ebay intercooler. We would not see nearly as high of a gain adding boost going from 19psi as we did from 13psi where we started. We really would need a better intercooler to unlock everything this combo has past this power level.
In reality the gains we saw going from 16-17psi to 18-19psi weren't that great either so it's definitely a bottle neck past this power level.
Originally Posted by SSZ
Nice numbers for sure. ALso nice to see some LT1 exposure once in a while.
Is this still using the stock computer or an upgrade?
If stock what tuning tool did you use?
Nice work.
It has been swapped over to a LS1 0411 PCM, 24x signal and LS coils via an EFI connection 24x swap.
It is still using the stock LS1 0411 computer which is perfect for this application.
Thanks!
Old 06-05-2014, 05:48 PM
  #63
Bimmerdude's Avatar
Do you have a lot of experience with the total seal rings? They've always looked interesting and worthwhile at PRI, but I've only built one motor and used the rings my pistons came with.
Old 06-05-2014, 06:52 PM
  #64
LS1Tech Sponsor
saccitycorvette's Avatar
wow sure makes good power. Is this with meth and pump gas? how much timing?
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 06-05-2014, 07:16 PM
  #65
Sales@Tick's Avatar
They are a great product.
Their gapless rings are second to none in racing apps IMO.
93 octane pump gas and dual 15gph nozzles. On 19psi it's running 18.5* at red line and 16* at peak torque.
IMO it's severely under timed based on the plug readings, but safe and it will hold together for a long time to come.
Old 06-05-2014, 08:18 PM
  #66
LS1Tech Sponsor
Oh wow thats so far under timed. You can probably run closer to 25deg on a lt1. Awesome build btw
__________________
Old 06-05-2014, 08:23 PM
  #67
Tiago's Avatar
cool project!!
Old 06-05-2014, 08:31 PM
  #68
Ryans_pewter_ss's Avatar
Badass! Saw the car in person Monday while I was there, very good looking car and build!!! Those numbers are crazy! Tick Performance is a great shop! I went with them several years ago and decided to give a different shop a chance last year, needless to say I was back at Tick Monday where I will keep my business from now on!
Old 06-06-2014, 09:07 AM
  #69
Sales@Tick's Avatar
Yea, just going off plug readings there is no heat in them at all. Timing mark is well before the bend in the flat portion of the strap. Still cadium plating on the plugs with no sign of a straw coloration anywhere.
Easily could add 4 degrees. We saw a 30-35rwhp/35-40rwtq gain with each 2 degrees of timing we added. I would imagine we'd be well over 900rwhp/900rwtq if MBT was reached.
Originally Posted by Tiago
cool project!!
Thanks Tiago!
Ryan, it is very unfortunate the issues and experience you had with your car. It made great power while it was here, and I'm glad you felt comfortable and also enjoyed being in our shop.
Glad to have you back!
Old 06-06-2014, 02:06 PM
  #70
kline454's Avatar
Originally Posted by Martin@Tick
Total Seal rings.
It has been swapped over to a LS1 0411 PCM, 24x signal and LS coils via a EFI connection 24x swap.
Thanks!
Nice work guys! and FYI I ran a half filled lt1 block in my car for years, no cooling problems or oil temp problems, just ran a 7qt pan, had over 8,000 street miles that way.
Old 06-06-2014, 04:56 PM
  #71
Sales@Tick's Avatar
Do you know of anyone that has popped a stock LT1 block?
Or anyone else?
Old 06-06-2014, 05:08 PM
  #72
Moderator
BizZzatch350's Avatar
Or anyone else?
Not unless some thing internal let go like a rod and caused a major failure to the block. Jose at Forced Inductions made 1000RWHP with his '97 SS, he had a customer with a six speed 355 Formula that trapped well in to the mid 150s with an 88MM set up. Dave Lewis who owns the LMR Drag Firebird made 970RWHP+ with a blower nitrous combo back when that car was a street car and had an MTI 383 LT4 in it. All those where street cars like yours.
Old 06-07-2014, 03:17 PM
  #73
Sales@Tick's Avatar
Very nice! Thank you for the information.
We're really just playing it safe right now, but with the information I've been gathering with help from this thread and other contacts, it looks like we can take it up if the owner wants to.
This car is stupid fast on the street. Full boost comes in at 4000rpm and when it does the amount of torque this engine makes is flat out ridiculous. The valve events are spot on for this combo and just makes torque everywhere. On the dyno power was falling at 6500rpm, but on the street you can't even tell.
With the intercooler we're using I don't see adding boost giving us much more power. Going from 12psi to 16psi on 16* timing to redline bumped us from 650rwhp to 775rwhp. Going from 16psi to 19psi only gave us 820rwhp. Going from 16* timing to 18.5* timing after peak torque to red line took us to 850rwhp so it really wants more timing.
Probably give it some more timing and take it over 900rwhp/850rwtq.
This car should trap every bit of 150mph in the 1/4 IMO.
Old 06-08-2014, 01:38 PM
  #74
unforgiven's Avatar
Nice build! I see you are using a Spec Stage 3 clutch. Holding up well, any issues?
Old 06-08-2014, 08:25 PM
  #75
kline454's Avatar
I've cracked #7 cylinder before it was hard blocked making 850rwhp. Block was .030 over. Tune was alittle lean. Never had any other block problems
Old 06-08-2014, 09:52 PM
  #76
Sales@Tick's Avatar
It has less than 250 miles on it so it's hard to tell at this point.
Old 06-08-2014, 10:12 PM
  #77
97WS6SCharged's Avatar
The weakest part of the LT1 block (structurally) is probably going to be the main caps. After that, the stupid oil pump drive.
Old 06-08-2014, 10:42 PM
  #78
Sales@Tick's Avatar
It would seem we have the main cap issue covered at this power level then!
Old 06-10-2014, 06:43 AM
  #79
w94rx7tt's Avatar
Give Tyree Smith a call at Tytech in Lewisburg TN 931-359-6869. He rarely answers the phone, but leave a message and he will call you back. He built Stefan Destito's car Firebird in X275.
Old 06-10-2014, 10:11 PM
  #80
Sales@Tick's Avatar
Josh@Dynospeed Elam told me about that car as well.
Damn impressive and my hat goes off to Tyree! I may give him a call...
Quick Reply: Tick Performance LT1 turbo build 907rwhp/860rwtq 19psi
