gt91 smaller displacement or larger displacement
Old 01-20-2014, 09:45 PM
flarhoades's Avatar
Default gt91 smaller displacement or larger displacement
I have a gt91 and currently building a 408. I want to know if I'm wasting my time? Should I build it and see what happens or sell the 408 and build something smaller?
Old 01-20-2014, 09:54 PM
HexenLord's Avatar
..... another one of these?
What exactly are you expecting not to happen by running it on your 408?
Old 01-20-2014, 09:58 PM
flarhoades's Avatar
A lot of people have been telling me the 408 is getting ran down in the big end by stock displacement 6.0L. I've put a lot of money towards this build and don't want to go in the wrong direction.
Old 01-20-2014, 10:03 PM
slowlsx's Avatar
The right combo with any displacement is going to fly, its not all about cubic inch. Dont overthink it, build your motor and let it eat
Old 01-20-2014, 10:52 PM
cjmatt's Avatar
What size turbine wheel and A/R turbine housing? I honestly think the ideal setup would be an S483 bullseye with a built 4.8 and good set of heads. nobody seems to have built one though
You just need a bigger hotside and itll work fine with the 408 though. Look at Joses GT55's theyll work great on a big 408
Old 01-21-2014, 06:34 AM
Cam72aro's Avatar
408 gt 91/ 94 here. Runs really well. Build it and let it eat.
Old 01-21-2014, 10:46 AM
flarhoades's Avatar
It's a gt91 with an ar housing of .75 with a t6 flange. Do you think this is gonna hurt me.
Old 01-21-2014, 10:51 AM
trans2000am's Avatar
Wow that ar is tiny are u sure that's correct? U will run out of stem quick
Old 01-21-2014, 10:54 AM
flarhoades's Avatar
I'm a post pic of the turbo but you can change these ar housing correct?
Old 01-21-2014, 11:31 AM
Cam72aro's Avatar
I didnt think that housing was an option. I thought .96 or 1.08. Is it a t6 or t4 flange?
Old 01-21-2014, 12:52 PM
flarhoades's Avatar
I can't post the pic but it says .75 are they interchangeable and yea it's a t6 flange
Old 01-21-2014, 05:13 PM
SPRAYED 01's Avatar
Comp ar?? No way that is the turbine side ar
Old 01-22-2014, 09:12 AM
flarhoades's Avatar
On the intake side it says a/r. 75 I'll have to look at the exhaust side tonight by the way how do you attach a picture here
Old 01-23-2014, 06:49 AM
hardbodeez's Avatar
What?
Ask Skinnies how often his car gets ran down in the big end.
Old 01-23-2014, 07:25 AM
Cam72aro's Avatar
A big inch motor with a big turbo will make more power period. It's just in sizing and combo. On the extreme ends put a 600+" motor against a 4.8. Both with twin turbos, who will win?
Old 01-23-2014, 07:53 AM
rotary1307cc's Avatar
More turbine. That is the same turbine as the standard pt88
Old 01-23-2014, 08:10 AM
HexenLord's Avatar
Depends on the turbos.
Old 01-23-2014, 08:57 AM
Cam72aro's Avatar
Sized correctly a big motor will win every time, it moves more air. I know a lot of little motors that run good, but a 300" motor vs a 706" or bigger has the advantage given the right turbos are installed. It builds more torque and more hp,
Quick Reply: gt91 smaller displacement or larger displacement
