Power brake boost and trans modulator etc - under boost
My brake booster worked fine only thing that sucks is staging the car as I loose vacuum and get into boost I start to loose some breaking power. I also have a th400 that uses only vac and would not shift under boost a tbrake manual valve body fixed that but I'm sure you can find a check ball
I have no idea what happened with my car. nor do I really understand how a vacuum boost works, but I can tell you.
When I would take my car out for hard pulls.. The booster would get filled with boost and GET STUCK. Driving home from work a couple times, the brakes would just lock up, I had to pull over and unplug the booster line.
Never figured it out. Going to manual brakes.
