Who to buy a turbo cam from....
Brian Tooley? Lil John? Tick?
Im sure you can't really go wrong. Ive heard great things ab them all. I see a lot of people using the triple 12 for their turbo. Id like to get a cam ground to exactly what I want tho. Who are all you guys using? My goal is faster spooling bc I'm using a T56, with twin 61mm turbos on a iron 5.7. LS6 intake, CP forged pistons. Forged Lunati pro comp rods. 317 heads 3 angle valve job, .660" valve springs, roller hydraulic lifters (or whatever is best for the cam) looking for 801rwhp on 15-18lbs of boost, pump 93 gas, no meth but it is intercooled.
Martin@Tick done my cam. Its at full tilt 21psi by 3500ish. I have a s475 on a stock (beside cam stuff) ls1. The turbine is the 96mm one also. Twins im sure would spool even faster. Heres a street hit in 4th I made Saturday with my cell phone. You can see the boost vs rpm in the video. Speedo is way off because of big tires.
Lol I didn't even look that close. But we are talking bout 21psi here which is right at the turbos limit. I think there is a good range to be at for response of spool and I like where mine is lol.
I'll admit I was wrong. I went back and paused the video myself. It is dead on 4000rpm at 21psi. But also its 16psi at 3500rpm.
I made 775 at 16psi. Pump gas tune and low timing. Just spray some meth to help my stock parts stay alive. I have no clue what rwhp its making at 21psi. It feels like night and day dirrence going from 15 to 21.
Meth will just help push further on pump gas. I plan on forged internal same cubes to go way over 1000rwhp on pump/meth. 750ish or so shouldn't be an issue on pump gas alone. Keep afrs in low 11.0 range should be fine.
Op call Martin up and just give him your specs and wants and he can set you up with the right cam.
